 Bricasti M28
Rene
Posted - 2014/05/04 :  12:02:40  Show Profile  Visit Rene's Homepage Send Rene a Private Message  Reply
Så kom deres længe ventet Monoblokke.
vi har lagt hånd på et sæt som skal bruges til demo og demo udlån så hold dig ikke tilbage.
Pris pr sæt 185000dkr.
Specs:
#8226; Class A/B design
#8226; 25db gain
#8226; 200W 8ohm 400/ 4ohms 800/2 ohms, for current delivery it will double
down to 2 ohms and should not have any problem with some speakers that have low impedance dips at some frequencies.
#8226; THD + N is .0009% at full power at all impedances.
#8226; Fully differential design, providing completely balanced signal path
from input to speaker output.
#8226; Stepped attenuator in 6 db steps at the rear of the amps to easily
match level gains with any source or more importantly the M1 to optimize the analog gain structure when using it as a line pre to drive the amps. ( highly recommended )
The M28 is designed to work directly with the M1 as a matched system in a
very unique way. Internally the M1 utilizes a fully differential DAC,
therefore at the start of the sound as it becomes analog, it is a true balanced signal, and this is maintained to the output of the M1. When connected to the balanced in of the M28, we can then achieve a fully
balanced signal path from the DAC to the speaker. The result when used
this way is quite remarkable, the sound is clear deep, fast and dynamic, with exceptional bass control, all with very low distortion. The harmonic content is preserved as you might expect with a tube amp, but with very low distortion, and excellent control of the low frequency drivers.
www.vassagohifi.dk
