 Dynaco VTA ST -120
Page: of 3
dB
Posted - 2013/12/23 :  10:25:59  Show Profile Send dB a Private Message  Reply
En liten låda dök upp i Posten för några dagar sedan....
Avsändare Mr. Bob Latino
Hifiberry digi+/Volumio, Thorens TD125 MKII, Harmony Design V9 RIAA, Schiit Audio Gungnir DAC, DIY Rörförsteg,Bob Latino VTA ST-120, Piega Premium 50
Edited by - dB on 2014/02/20 09:45:21
Wing Zero
Posted - 2013/12/23 :  10:38:33  Show Profile Send Wing Zero a Private Message  Reply
Riktigt fin julklapp :)
Musik är livet
dB
Posted - 2013/12/23 :  10:56:01  Show Profile Send dB a Private Message  Reply
Och i lådan hittar man....
massor med godsaker
Posted - 2013/12/23 :  11:00:51  Show Profile  Visit Ryssen's Homepage Send Ryssen a Private Message  Reply
spännande!
dB
Posted - 2013/12/23 :  12:22:11  Show Profile Send dB a Private Message  Reply
Japp, riktigt spännande!
Det blir en VTA ST -120 med 4st KT120
En upphottad variant (minst sagt) av gamla Dynaco St70 klassiker. Det är en hel del som är nytt. Här är en liten sammanfattning
1. A new STAINLESS STEEL chassis that is identical
in size, shape and markings to the older
original nickel plated steel frame. This chassis is
NON-MAGNETIC and removes any magnetic
interference effects of a steel chassis on the audi
o circuitry.
2. Quality USA made A-260-120 custom wound output t
ransformers which are interleaved/layer-
wound and incorporate high quality M-6 grain orient
ed laminations.
3. A more robust PA-060-120/240 power transformer rated
at 120/240 volts, having 420-0-420 secondaries
and a 450 milliamp current transfer capability.
4. Quality Celanex#8482; tube sockets
5. All stainless steel screws with zinc plated kep
nuts
6. An 80, 40, 30, 20 main electrolytic cap with a 5
25 volt continuous use rating.
7. An all triode VTA driver board made of mil-spec
epoxy fiberglass. This board also contains an on
board bias supply for the output tubes and eight pr
emium Sprague 716P film and foil coupling caps.
8. Gold plated input and output terminals.
9. A dual choke system rated at 400 milliamps
10. Triode/pentode switches to allow the amp to run
in two modes of operation
11. A supplementary cap module with ESL reduction capacitors
Med 4st KT88 ska den klara av att leverera 60w pentod/ 30w triod, med KT120 ska det vara lite mer (vet inte exakt men 8-10% mer)
dB
Posted - 2013/12/23 :  17:10:05  Show Profile Send dB a Private Message  Reply
Lika bra att sätta i gång med monteringen
Vox
fd. Eric V-ås
Posted - 2013/12/23 :  17:38:33  Show Profile Send Vox a Private Message  Reply
Läckert......
sladdbarn
Posted - 2013/12/23 :  18:19:36  Show Profile Send sladdbarn a Private Message  Reply
Skoj!!
Drömmer om bra ljud...
Posted - 2013/12/25 :  10:49:24  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message  Reply
Fint julpyssel.
Tomas J
fd _T_
Posted - 2013/12/25 :  12:54:08  Show Profile Send Tomas J a Private Message  Reply
Vad gör socklarna på baksidan?
Jag vet att quad har kört med något liknande...
Häftig byggsatts i övrigt, detta kommer att följas!
Vox
fd. Eric V-ås
Posted - 2013/12/25 :  13:31:25  Show Profile Send Vox a Private Message  Reply
Nu är det bara 1,5 dygn kvar av julhelgen så hur långt har du kommit?
dB
Posted - 2013/12/25 :  13:36:41  Show Profile Send dB a Private Message  Reply
Detta är framsidan, tro det eller ej. Socklarna används för justering av BIAS. Bob Latino har valt att försöka bevara den ursprungliga utseende på Dynaco ST70 - där av lite "annorlunda" detaljer.
Mer info finns på:
http://www.tubes4hifi.com/bob.htm#ST120
http://dynacotubeaudio.forumotion.com/search?mode=searchbox&search_keywords=vta+st120&show_results=topics
En jämförelse mellan VTA ST 120 och McIntosh MC275
http://dynacotubeaudio.forumotion.com/t1930-comparing-my-vta-st-120-with-my-mcintosh-mc275
/dB
dB
Posted - 2013/12/25 :  13:39:23  Show Profile Send dB a Private Message  Reply
VTA och TDR boards monteras just nu. Mitt mål är att vara klar den 27
Bardis
Posted - 2013/12/25 :  14:44:14  Show Profile Send Bardis a Private Message  Reply
Ta det lugnt så du kan vara noggrann.
Kul med nyproduktion av Dynaco-stegen.
Modda allt som går att modda!
dB
Posted - 2013/12/26 :  20:05:26  Show Profile Send dB a Private Message  Reply
VTA & TDR kort.
Ryska PIO kondensatorer monteras på andra sidan VTA kortet
En del kvar att göra....
Bardis
Posted - 2013/12/27 :  11:58:42  Show Profile Send Bardis a Private Message  Reply
En bra bit på vägen!
Dokumentationen verkar ok. Ser bilden på det färdigkopplade steget vid sidan av apparaten.
dB
Posted - 2013/12/27 :  20:36:03  Show Profile Send dB a Private Message  Reply
Dagen bild
Ett steg till närmare målet
Dokumentationen är riktigt bra! Med varje byggsats kommer detaljerad "steg för steg" byggbeskrivning samt färgfoto på färdigbyggd förstärkare och en ritning. Underlättar verkligen!
PG Jeppsson
Posted - 2013/12/27 :  21:19:25  Show Profile Send PG Jeppsson a Private Message  Reply
Jag måste säga att det ser bra ut .
Bra tråd....
Är numera säljare av
biostimulerande grejor.....
Är lagliga grejor.......
dB
Posted - 2013/12/30 :  22:46:12  Show Profile Send dB a Private Message  Reply
Jag har haft vissa förhoppningar om vad den skulle prestera men absolut inga förväntningar. Resultatet blev ett veritabelt haksläpp.
Ska sammanfatta kort:
Ljudkvalité
Ljudkvalité
Ljudkvalité
Ljudkvalité
Ljudkvalité
Pris
Känslan man får när man inser att resten av mina förstärkare troligtvis kommer att samla damm i fortsättningen
Känslan man får av ett lyckat #8221;pappa/son projekt#8221;
Utseende
Utseende
blir riktigt varm
Summa summarum- finns det bättre förstärkare i världen? Troligtvis, men jag har hittills hört ytterst få. Vad den lilla krabaten presterar är otroligt.
Bergfast bas, dynamik, upplösning,... Jag skulle kunna rada upp hur många hifi klyschor som helst.
En otrolig förstärkare helt enkelt.
Gott nytt år allihopa!!!
Posted - 2013/12/30 :  23:07:17  Show Profile  Visit AlfaGTV's Homepage Send AlfaGTV a Private Message  Reply
Stort grattis till ett väl genomfört julprojekt!
Fina bilder!
Vox
fd. Eric V-ås
Posted - 2013/12/30 :  23:38:44  Show Profile Send Vox a Private Message  Reply
Snyggt jobbat. Hur många timmar tog det?
Tomas J
fd _T_
Posted - 2013/12/31 :  09:08:39  Show Profile Send Tomas J a Private Message  Reply
Varför står det utseende på - sidan?
Den är ju hur snygg som hellst!
Grattis till det lyckade resultatet!
HerrD
Posted - 2013/12/31 :  09:24:10  Show Profile Send HerrD a Private Message  Reply
Läckert! Grattis till resultatet, får man fråga vad det kostar att få en till Sverige? Får vi en närbild på lite glöööööd?
Richard P. Feynman
dB
Posted - 2013/12/31 :  12:31:56  Show Profile Send dB a Private Message  Reply
Hej,
Tomas J
Utseende/design får både + & -. Slutsteget är riktigt snyggt men ergonomi kan ifrågasättas. Grundidé bakom ST120 är att ha originalutseende med modern innehåll. PGA detta har man två st rörhållare på framsidan (användes för att få ut spänning till försteg på den gamla ST70) samt RCA kontakter. Kan vara bökigt med att ha ingång på framsidan.
HerrD
Det finns olika möjligheter/priser
Mitt slutsteg :
ST-120 amp kit > $889 USD
240 volt power transformer > $50 USD
Both cap upgrades > $45 USD
TDR kit > $35 USD
Weber WZ68 > $30 USD
Total = $1049 + $146 USD = $1195 USD
1200$ inkl frakt gick det på.
Andra möjligheter:
*VTA ST-120 KIT with NO TUBES > $889 + shipping
*VTA ST-120 KIT with all tubes > $1079 + shipping
*VTA ST-120 WIRED and TESTED amp with NO tubes > $1285 + shipping
*VTA ST-120 WIRED and TESTED amp with all tubes > $1475 + shipping
Jag valde att skaffa andra rör än vad Mr.Latino erbjuder. 4st KT120 går på ca 200$ och 3 st Brimar 12AU7 ca 500 SEK. För dessa pengar fick jag den absolut bästa slutsteg jag nånsin har ägt. Jämförde den med Luxman MQ360 imorse#8230; Det fanns ingenting att jämföra. ST120 vinner på alla punkter.
Vox
Man tackar! Tar ca 20 timmar att få ihop allting.
Har tyvärr ingen bra kamera som kan visa den fina glöd, men bifogar ett kort som visar hur det ser ut när det glöder som finast
ninja
Posted - 2013/12/31 :  12:43:48  Show Profile Send ninja a Private Message  Reply
Grattis DB!
Gott Nytt År!
Vox
fd. Eric V-ås
Posted - 2013/12/31 :  12:46:07  Show Profile Send Vox a Private Message  Reply
Vilka typer av verktyg krävdes?
