 Loudness war
Zombie
Posted - 2012/03/03 :  19:24:56  Show Profile Send Zombie a Private Message  Reply
Vet inte om den har varit upp förr: http://www.dynamicrange.de/
solhaga
Posted - 2012/03/03 :  23:55:42  Show Profile Send solhaga a Private Message  Reply
Verkar intressant.
Har du koll på hur man får tag på en körbar variant?
På websidan står det:
"This version has an expiration date set to 31 August 2011. Around this date an update is planned for the Dynamic Range Meters and this foobar2000 component."
Och när försöker köra pluginen får man:
"This foobar2000 component has an expiration date set to 1 September 2011. Around this date the Pleasurize Music Foundation has planned an update for the Dynamic Range Meters and the foobar2000 component. These releases will have an updated algorithm for the DR metering.
Please update this component. The latest information can be found on the website www.pleasurizemusic.com."
Edited by - solhaga on 2012/03/03 23:57:57
solhaga
Posted - 2012/03/04 :  00:01:27  Show Profile Send solhaga a Private Message  Reply
Google är bra:
http://www.jokhan.demon.nl/DynamicRange/index.htm#Download
solhaga
Posted - 2012/03/04 :  00:17:12  Show Profile Send solhaga a Private Message  Reply
En första test på två låtar från Paul Simon So beautiful or so what.
Borde det inte ha varit någon skillnad?
24/96:
foobar2000 1.1.11 / Dynamic Range Meter 1.1.1
log date: 2012-03-04 00:12:14
Analyzed: Paul Simon / So Beautiful or So What
DR Peak RMS Duration Track
DR7 -0.03 dB -9.00 dB 4:06 01-Getting Ready For Christmas Day
DR7 -0.22 dB -9.95 dB 3:40 02-The Afterlife
Number of tracks: 2
Official DR value: DR7
Samplerate: 96000 Hz
Channels: 2
Bits per sample: 24
Bitrate: 3362 kbps
Codec: FLAC
16/44:
log date: 2012-03-04 00:15:31
DR7 -0.01 dB -8.99 dB 4:07 01-Getting Ready for Christmas Day
DR7 -0.01 dB -9.48 dB 3:40 02-The Afterlife
Number of tracks: 2
Samplerate: 44100 Hz
Channels: 2
Bits per sample: 16
Bitrate: 1046 kbps
Codec: FLAC
MatsT
Posted - 2012/03/04 :  12:36:37  Show Profile Send MatsT a Private Message  Reply
MasVis är ju populär på sina håll och kan väl ge vettig information för den intresserade. Får användas av vem som helst och laddas ned här:
http://www.lts.a.se/lts/masvis
Jag tycker personligen att det räcker bra med en provlyssning för att avgöra om resultatet är bra. Det finns fler parametrar som avgör om det låter bra eller inte och varje gång någon hittar på nåt nytt sätt att mäta finns det en tendens till att titta lite för mycket på detta och glömma helheten.
Program av den här typen ger dock bra diskussionsunderlag vid jämförelse av inspelningar och databaser med olika versioner av samma alster kan ju vara intressant för att hitta den bästa versionen. Jag stöder förstås alla initiativ som hjälper till att få bort "dumkomprimeringen".
solhaga
Posted - 2012/03/04 :  14:42:48  Show Profile Send solhaga a Private Message  Reply
Verkar inte klara 24/96 flac?
FalloutBoy
Posted - 2012/03/04 :  14:48:57  Show Profile Send FalloutBoy a Private Message  Reply
Varför borde det varit skillnad? Det är ju hur materialet är inspelat/mastrat som bestämmer dynamiken och inte formatet.
Edited by - FalloutBoy on 2012/03/04 15:01:24
solhaga
Posted - 2012/03/04 :  15:10:44  Show Profile Send solhaga a Private Message  Reply
Ja, då är ju det en indikation på detta.
Då borde Paul McCartneys "limitless" utgåvor uppvisa en skillnad.
Edited by - solhaga on 2012/03/04 15:23:11
