 Inbyten och demo säljes
patrikcaesar
Posted - 2010/03/05 :  23:55:31  Show Profile Send patrikcaesar a Private Message  Reply
-Gamut CD 3 Aktuell modell (54 000:-) 25000:-
Nyskick
-Audio Research mp 1 (Aktuell modell) (70000:-)
45000:- Nyskick.
..."my recommendation, it's ready availability -- from a renowned company, no less -- and outstanding functionality would likely push it to the top. The fact that its sound is so good makes it a no-brainer. The MP1 is the multichannel preamp to buy, and the one I'm recommending to friends. I can't make it any clearer than that" Jeff Fritz Soundstage "Recommended products"
jeff@soundstage.com
-Theta Dreadnaught 2,
5 kanal slutsteg 3* 225 w i front & center, 2*100
w i bakkanalerna. (75 000:-) 40000:- Bra skick
"Details include a truly balanced differential design, with zero global negative feedback, and Class A characteristics, leading to a very quiet, clean sounding amplifier for both stereo and multi-channel listening. When driving my speakers, the Dreadnaught II produced a substantial improvement in sound quality over my previous amplifier setup. I bought a seven-channel version for my HT system." Steve Smallcombe, Secrets of Home Theater & High Fidelity
-Theta Casablanca 2 (95000:-) 35000:- Bra skick
"There are no ifs, ands, or buts here. The Theta Casablanca II is a world class processor. Although it is very expensive when fully loaded, you can get the basic system at a reasonable cost and add to it over time. It is totally upgradeable and therefore never out of date. It is definitely a reference product by which just about everything else can be compared. It's beautiful and built like a tank. It sings like an angel. There can be no higher recommendation." John E. Johnson, Secrets of Home Theater & High Fidelity
-Audiovector Mi3 Avantgarde SE i lönn 19500:- Nyskick
När man utvecklade den avancerade S6-serien, så provade man tre av S6 Avantgardes fyra element i ett M3 Signature-kabinett. Det föll väl ut och ett halvår senare var M3 Avantgarde född. Nu kan vi presentera nästa generation av högtalaren, Mi3 Avantgarde.
Audiovectors spektakulära Avantgarde-diskant tillsammans med mellanregisterelementet Evotech P2004 transformerar Mi3 Signature till en nivå som vi inte trodde var möjlig. En kombination av första klassens High End tranparens och musikalisk timing skapar en spelglädje som tidigare varit svårfunnen oavsett prisklass. Mi3 Avantgarde kostar mer än övriga modeller i Mi3-serien men tack vare Audiovectors unika uppgraderingsprogram, kan man börja med en billigare modell och därefter förfina denna ända upp till Avantgarde-nivå.
-Pathos Classic one MkII (Nypris 25 900:-) 9900:- Bra Skick
Main Specifications:
Type: Integrated amplifier with remote in Class A/AB, hybrid circuit with input tube stage, bridgeable
Output Power: 2 x 70W @ 8 Ohm, 2 x 130W @ 4 Ohm, 270W in bridged mode (mono)
Inputs: 5 line, including one balanced (XLR)
Frequency response: 2Hz ÷ 100kHz
THD: <0.05%
Signal/noise ratio: 90dB
Input impedance: 100kOhm
-Kuzma Stabi S extended med Stogi Ref 313.(Nypris 59500:-) demo 39000:-
En 13 tums arm med en stabilitet som saknar motstycke, tar alla pickuper hur tunga de än är. Med motorstyrningen är detta en av de bästa skivspelare man kan få tag på.
Vill du köpa en av sakerna, men vill pruta så betänk att diskssioner som börjar med trams avslutas ganska snart, men jag är öppen för seriösa förslag.
Showroom i Skånes mitt.
patrikcaesar@yahoo.com
0737 61 43 83
Edited by - patrikcaesar on 2013/09/24 19:35:09
