 One Transistor Amplifier
rhr9
Posted - 2007/12/15 :  17:23:05  Show Profile Send rhr9 a Private Message  Reply
Hi there ,
This is my first post in this section , and I want to
present my OTA using just one IRF150 per chanel ,working in class A.
Each chanel has its own power supply .
[URL=http://imageshack.us][/URL]
The initial topic is here :
http://www.diyaudio.com/forums/showthread.php?s=e2f493a586a0883010b6e2b8eb93b548&threadid=73598
Did anybody else build this amp ?
Best wishes !
@ + Philippe.
Posted - 2007/12/15 :  18:10:10  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message  Reply
Nice work!!! How´s the sound?
rhr9
Posted - 2007/12/15 :  18:28:54  Show Profile Send rhr9 a Private Message  Reply
Hi Bernt ,
It sounds lovely on my FE208 Fostex Full range drivers ( 98 dB ) .
I am using a tube preamp to drive properly the OTA .
@ + Philippe.
Posted - 2007/12/15 :  21:17:52  Show Profile Send Micke Y a Private Message  Reply
Very nice amplifier, very good with MY speakers . What kind of effect do you get out of that transistor? Do you use feedback?
Michael
ohmega
Posted - 2007/12/16 :  07:12:42  Show Profile Send ohmega a Private Message  Reply
Philippe: Wow..love it....built like a tank..
CarlssonH
Skämtsam
Posted - 2007/12/16 :  10:04:22  Show Profile Send CarlssonH a Private Message  Reply
Is this a version of "The Monster" designed by Jean Hiraga?
Anyway, it really is a beauty
A balanced diet is a cookie in each hand.
rhr9
Posted - 2007/12/16 :  10:33:37  Show Profile Send rhr9 a Private Message  Reply
Thanks for all your appreciations !
This amplifier doesn' t use any feedback . It has got a bias current of 3 Amp . The sound getting out of the IRF150 is very realistic , very dynamic , as if you could touch each instrument that you listen to .
It isn' t a version of Jean Hiraga's 8W Monster . I am going to build it also , on a battery version . On the Monster Amp , there are 8 transistors per chanel .
@ + Philippe.
