 Squeeze box VS High-end cd.
Hinken74
Posted - 2006/12/15 :  18:52:01  Show Profile Send Hinken74 a Private Message  Reply
Hur passa nära en riktig high-end cd tror ni klämlådan kan komma om man kör den med en extern dac och ev seperat strömförsöjning?
Nu jämför jag med typ Gondul M, Audio-Aero Capitole Ref samt övriga high-end spelare...
Mvh/Henrik
Mitt system:
Von Schveikert db99,
Audio aero capitole Prestige SACD SE
Octave V70 samt strömrenare från Agile
Edited by - Hinken74 on 2006/12/15 18:52:24
Martin.M
Posted - 2006/12/15 :  19:27:01  Show Profile  Reply
För att citera Atkinson på stereophile
For the purposes of this short report, I auditioned the Squeezebox exclusively from its digital output feeding an outboard DAC. (I'll report on the quality of the SB's analog outputs, and provide a full set of measurements, in a future issue of Stereophile.) The Squeezebox performed superbly in this role. There was a cleanness to the sound that I didn't get from the Airport Express's digital output feeding the same D/A. Comparing the original CD on the Ayre C-5xe disc player, its digital output driving the Levinson DAC via a 1m DH Labs AES/EBU link, with SlimServer feeding an ALC-encoded file to the Squeezebox with its digital output feeding the Levinson via the AudioQuest OptiLink-5, I was hard-pressed to hear much of a difference. Perhaps there was an increased sense of authority to the sound of the CD on the Ayre used as a transport, a better sense of extended low frequencies—but when I'm not listening seriously, the difference is irrelevant. Even when I am listening seriously, I have to strain to hear that difference (as long as I'm not listening to lossy-compressed files).
Idiosyncrasies? The beginnings of some files were occasional
Han har alltså svårigheter att höra skillnader när han lyssnar öppet, tänk ett blindtest, inte en chans i helvetet att det går att skilja dom åt, möjligtvis till Squeezeboxens fördel då pga att den alltid matar ut en perfekt signal utan möjliga läsfel etc.
Edited by - Martin.M on 2006/12/15 19:27:32
forken
semester på egen begäran
Posted - 2006/12/15 :  20:21:55  Show Profile Send forken a Private Message  Reply
Gissar att den kommer låta väldigt bra.
Edited by - forken on 2006/12/25 16:39:38
Björn-Ola
Posted - 2006/12/17 :  12:00:41  Show Profile Send Björn-Ola a Private Message  Reply
Den fick väldigt bra kritik i High Fidelity som transport.
Själv har jag gjort en snabb jämförelse med Sony CDP X5000 som har ett gott rykte som transport och den som låtit bäst hitintills hemma hos mig.
Jag upplevde faktiskt mer kroppskänsla och tydlighet med SB men samtidigt lite väl markerade s-ljud.
Edited by - Björn-Ola on 2006/12/17 12:01:12
