 Bluenote Steroid 1 MKII int. förstärkare SÅLD!
Henrik Nilsson
Posted - 2006/09/25 :  15:08:01  Show Profile Send Henrik Nilsson a Private Message
Hejsan!
Tänkte sälja min förstärkare för övergång och test av rör. Sitter inbyggt phonosteg och den lilla runda fjärren med volym. Kvitto från 051001 samt kartong finnes. Hämtas i Malmö, men kan kanske skickas. Men hämtköpare önskas.
Lite fakta om den:
The Steroid 1 mkII is a Stereo Integrated Amplifier with 5+1 inputs and 30 watt per channel into 8ohms. The front panel is made with Polished black Acrylic. It is hard to describe our super bargain amplifier. This amp is a new, apparently simple way, to realise solid-state amp sounding like good tube amps with twice their power. The Steroid 1 mkII sound is open, natural and realistic quite like very expensive amps. It has just no competitors at its price point. The Steroid 1 mkII chassis is completely made of Steel to minimize electromagnetic fields RFI and EMI. Electronically all the active parts of the circuit are powered by different transformers. The Volume remoted control (optional), the self check out relays and even the ON led are separately powered by a specific transformers not to affect the audio signal path. The Steroid 1 mkII has not capacitors on the audio signal and to prevent blowing and dangerous risk there are 4 passive thermal switches cut out the AC power if the amplifier should work under electronic incompatible conditions. The Steroid 1 mkII can be market. It has not got inductive or resistance problems connected with any kind of regular or special audio cables, enabling users to look for their favourite combination.
Technical details DIMENSIONS: 430mm L x 90mm H x 350mm D INPUT/OUTPUT : 5 Line + 1 Phono (optional) + 1 fix output WEIGHT: Kg. 7,00 FREQUENCY RESPONSE: 1Hz - 25KHz @ +/- 3dB THD (Total Harmonic Distortion): 0,1% @ 20Hz - 20KHz PHONO INPUT IMPEDENCE (OPTIONAL): 47 Kohm (47Kohm MM o 470ohm MC) INPUT SENSIVITY: 550 mV (0,9 to 5,0 mV MM variable acceptance) (0,3 to 0,8 mV MC variable acceptance) RATIO SIGNAL/NOISE : -90dB SLEW RATE: 13 Volt Line POWER OUTPUT: 30w+30w 20-20.000Hz max. 0,2% THD POWER TRASNFORMERS: 1 AUDIO Power Toroidal Trafo – 1 Volume control
Mer info finns på www.audioconcept.se
Nypris: 11500:- inkl. phonosteg och fjärr.
Nupris: 5000:-
Nås via PM eller henrik.nilsson18@comhem.se
MVH Henrik.
Liten bild oxå, fler kan mailas vid intresse.
Original CD-A8T -> Audience Conductor -> Dared MP-7 -> ViaBlue SC-2 Red-Line -> Phonar Monitor IIs
Edited by - Henrik Nilsson on 2006/09/26 14:16:43
Mattias S
Posted - 2006/09/25 :  23:00:22  Show Profile Send Mattias S a Private Message
Du har mail.
Mvh // Mattias S
Anläggning: imac 27" - Audirvana Plus - Supra usb cable - Resonessence Labs Concero HP DSD hörlursförstärkare / dac - B&W P7 Wireless
Henrik Nilsson
Posted - 2006/09/26 :  09:00:45  Show Profile Send Henrik Nilsson a Private Message
Mattias S, du har mail.
MVH Henrik.
