 Ta bort. tack... Objektet på långdraget verkstadsb
CC
Posted - 2006/06/14 :  22:41:43  Show Profile Send CC a Private Message
Electrocompaniets dac, model ECD 1, är eventuellt till salu! Lite beroende på om intressanta bud gives...
(OBS! Texten nedan från http://www.electrocompaniet.no/products/digital/ecd1.html
The ECD1 is a 24Bit 192KHz upsampler DAC accepting 16 - 24Bit input and upsample it to 24Bit resolution.
For people who put the music in the front seat, the new format (DVD-A and SACD) with its present products do not fulfil or even compete with the best CD system.
Not knowing which format will "win" and the lesser sound quality produced by these products, we believe that a really good sounding CD system will survive for many years.
If a customer want to keep his/her CD player for some reason, or wait for the new format to prove its musical capability, upgrading the sound quality with the ECD1 is well worth the money spent.
This will give app. 10dB more headroom by lowering the noise floor, with more details reproduced.
The D/A converter is a sophisticated balanced 192KHz unit. Due to the higher sampling frequency and the cancellation of digital noise in the balanced system, the bandwidth is moved 2 octave up in frequency, compared to standard CD system using 44.1KHz sampling frequency, and therefore a 6dB rolloff can be used.
All analogue circuitry is fully balanced and symmetrical.
- With four input's and connection for AES/EBU ( balanced ), RCA and TOSLINK, all standard formats are covered.
Two digital output for connection to multichannel receiver's etc. TOSLINK (Optical) and RCA.
Analogue output's - Balanced and single ended.
The digital and analogue circuitry used in the ECD1 is the same as our EMC1 UP CD player.
The ECD1 will improve the sound from any CD player, bringing it to a High-End source.
Technical specifications
All measurements are made at 120V / 240V //50Hz / 60Hz
Analog stage
Output level(unbalanced) 1,6 V
Output level(balanced) 3,2 V
Gain(unbalanced) 1,6x(4dB)
Gain(balanced) 3,2x(10dB)
Maximum output(balanced) >14 V RMS
THD(1 V out, 1 Khz) <0,002 %
Channel separation(1 V out, 1 kHz) >90 dB
Equivalent input noise 4 uV
Analog filter(-3 dB) 75 kHz
Output impedance 100 Ohm
Digital stage
Dig. inputs XLR-AES/EBU, RCA,OPTICAL TOSLINK
Dig. outputs RCA,OPTICAL TOSLINK
Signal to noise 100 dB
Dynamic range 100 dB
THD -100 dB
Frequency response 20Hz - 20 kHz
Input / Output impedance(fixed) 75 Ohm
Sampling frequency in 32 - 96 kHz
Power consumption
(no load or signal) 15 W
Dimensions
Width 483 mm / 19 inches
Depth 255 mm / 10 inches
Height 83 mm / 3.2 inches
Weight 5 kg. / 11 lbs
Som sagt, bud någon? Kan jag få 8"?
- Oscar Wilde -
- Leonardo da Vinci -
Edited by - CC on 2006/09/06 23:53:56
Fimax
Posted - 2006/06/14 :  23:31:04  Show Profile Send Fimax a Private Message
gäller inte regeln att annonsen skall innehålla
* Pris eller prisidé.
de flesta här kan nog tänka sig att sälja sina prylar "om intressenta bud gives"...
/filip
Hifimannen
Posted - 2006/06/15 :  00:37:10  Show Profile Send Hifimannen a Private Message
hur gammal är den? Har du box?
CC
Posted - 2006/06/16 :  23:52:39  Show Profile Send CC a Private Message
Ca 3 år gammal.
Låda finnes.
- Oscar Wilde -
CC
Posted - 2006/06/17 :  02:30:29  Show Profile Send CC a Private Message
- Jaså
- Sorry, missat det! Åtgärdat
Tur att det finns vänliga själar som håller reda på oss lite slarviga...
- Oscar Wilde -
Saim
Posted - 2006/06/22 :  17:03:28  Show Profile  Visit Saim's Homepage Send Saim a Private Message
Var finns DACen?
Simon
CC
Posted - 2006/06/22 :  20:35:30  Show Profile Send CC a Private Message
Utanför Göteborg. Nära Landvetter.
- Oscar Wilde -
esl
Posted - 2006/06/22 :  21:47:24  Show Profile Send esl a Private Message
Snygg!!
Innovare necesse est.
CC
Posted - 2006/09/06 :  23:56:04  Show Profile Send CC a Private Message
Som sagt. Annonsen gäller inte längre pga ett löjligt extremt långt servicebesök här i Göteborg Fy f!
Blir den klar innan jul eller?
- Oscar Wilde -
