 SoundpaX NXT - Högtalare Kan köpa BILLIGT !!!
mace
London calling
Posted - 2003/11/30 :  13:17:40  Show Profile Send mace a Private Message
Se: http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=22793
Jag kopierade det hit eftersom tråden ändrade riktning
Verkar som om jag kan få dom för under £10 styck och det finns visst 15 styck i lager
Jag skickar gärna, skulle tippa på under £15 till dörren
Någon
M
mera quad ESL = mera välljud.
Mr 500!
mace
London calling
Posted - 2003/11/30 :  22:17:06  Show Profile Send mace a Private Message
Wellpapp är svanenmärkt o fint
100% biodegradeable
Bara det Ni
M
Mr 500!
mace
London calling
Posted - 2003/11/30 :  22:22:23  Show Profile Send mace a Private Message
FAQs från nxt's hemsida.
01 What are SoundpaX speakers?
SoundpaX™ speakers are the speaker equivalent of the Swatch watch. They're fun, funky, ultra-light and based on NXT technology. They are easy to store and can be pulled out and set up in an instant.
02 What are they made from?
Cardboard mostly with a motor we call an exciter to drive force into them.
03 If they're made of cardboard then surely they won't last long?
They're actually pretty durable but if they get stamped on too often then they clearly won't work as well.
04 Where can I get them?
We are currently talking to various brands and distributors about licensing them, but they are already on sale from www.firebox.com.
05 How do they work?
NXT loudspeakers are totally different from normal loudspeakers. Instead of using pistons, NXT technology turns flat surfaces into loudspeakers. A motor drives force into the panel and it vibrates, radiating sound. The material, its shape, the motor used, and how they are all combined are governed by some very complex rules of physics.
06 Will cardboard speakers be the way of the future?
NXT is looking to totally change the way people appreciate sound. These cardboard speakers are part of that but won't be suited to all situations.
Mr 500!
mace
London calling
Posted - 2003/11/30 :  22:24:58  Show Profile Send mace a Private Message
nxt igen
Specification
Frequency response: alarmingly good
Sensitivity: deeply felt
Power handling: loud enough to dance to
Impedance: 8 Ohms
Recommended amplifier power: ideally 10W-50W continuous but can be less
Power ratin : 6W according to IEC 268-5
Material: Acoustic Fluted Composite (AFC)KARTONG
Height: 720mm
Depth : 450mm, width: 540mm,
Weight: 0.9kg
WARNING: EXCESSIVE SOUND PRESSURE LEVELS CAN BE GENERATED BY SOUNDPAX LOUDSPEAKERS - BE PARTICULARLY CAREFUL IF PLACING YOUR HEAD INSIDE THE BOX (DITTO FOR PETS).
Mr 500!
mace
London calling
Posted - 2003/11/30 :  22:27:17  Show Profile Send mace a Private Message
Test i HiFiChoice:
http://www.hifichoice.co.uk/review_print.asp?ID=2032
Långt ingående test med BILDER:
http://audio-nirvana.fortunecity.net/pag_eng/soundpaxg.htm
Mr 500!
Edited by - mace on 2003/11/30 22:29:29
cittroman
Posted - 2003/11/30 :  22:49:25  Show Profile Send cittroman a Private Message
Ser verkligen intressant ut, kuliga saker.
glas är gjort av grus DS ;-)
Dr Fre
Posted - 2003/12/01 :  18:14:40  Show Profile Send Dr Fre a Private Message
Är detta på riktigt Vore ju grymt till korridorsfesterna i så fall!
mace, har du hört dem?
No hay banda
mace
London calling
Posted - 2003/12/01 :  21:35:38  Show Profile Send mace a Private Message
Har inte hört dom (än) har bara läst recensionerna
M
Mr 500!
mace
London calling
Posted - 2003/12/02 :  15:15:47  Show Profile Send mace a Private Message
Dom är lite långsamma i affären (JULTOKERI) Men jag tjatar o ringer o har mig
M
Mr 500!
Mace JR
Posted - 2003/12/05 :  12:18:18  Show Profile Send Mace JR a Private Message
Kanske vore nått för mig att ha och sälja här på campus
Brukar bli en del blöta fester!!
