 CD-spelare - hjälp efterfrågas!
Fred_J
Posted - 2003/02/24 :  11:39:03  Show Profile Send Fred_J a Private Message
Jag funderar på en CD-spelare, NAD 512 för 1000:- beg.
Jag läste en recension av den:
There was some disagreement about this player from members of the listening panel. On the whole, the NAD was not generally well received, achieving a disappointing average score of 3.5/10.
Criticisms were concentrated on two areas: the balance was generally thought to be recessed and distant with some lack of spatial and tonal depth. 'Shallow sounding', said one participant with reference to the Keb' Mo' track, while another remarked on the odd texture of the clarinet and piano, especially in the lower registers (Ravel).
The other main criticism voiced by the panel concerned a lack of expressiveness and dynamics. One judge expressed it as 'dynamically lacking in shade: everything appears to happen at one level'. He went on to describe the NAD as 'manipulative,' a word that appeared several times in the comments of others and was expanded on by another listener, 'Music is delivered in little discrete serial packages rather than as a coherent unified whole.' 'This player is becoming annoying to listen to,' wrote another judge in apparent disgust, but not everyone agreed. After a presentation of the Holst brass band piece, a third listener commented that 'Although it lacks the purity and extension of the best, this player is more lively and vital than most, with an easy, fluid presentation.' But in the Keb' Mo' track, he criticised the 'dry, pinched-sounding voice'.
I concede the criticisms, but heard them in a slightly different way. Expressed as plus and minus points, the 512 is sharp and well-defined, and extremely consistent both with frequency and level. Dynamics are strongly, if not very expressively, presented, and vocal intelligibility is of a high order. The sins of the NAD are presentational rather than structural. It sounds rather hard and grainy by the best standards, and it lacks the finest players' organic, liquid quality.
Håller ni med?
Jag har en NAD 3020 och ett par VH-1:or och nu vill jag ha antingen en DVD med bra ljud eller en CD-spelare (& en DVD).
Vad tycker ni om NAD 512? Är den värd sina pengar?
Hoppas någon av er kan svara! :)
SZR
Guran!
Posted - 2003/02/24 :  14:00:59  Show Profile  Visit SZR's Homepage Send SZR a Private Message
512 är kanske lite gammal (iofs 3020 också)?
Du borde kunna få en nyare (bättre) CD-spelare för ca 1000:-/1.500:-!
Men om den är i bra skick så...den matchar ju din 3020 utseensemässigt.
Men jag skulle nog pruta rejält !
En lite bättre DVD-spelare ger nog samma ljudkvalitet som 512:an.
//StefanZ
Edited by - SZR on 2003/02/24 14:02:53
Rollo
Posted - 2003/02/24 :  15:15:14  Show Profile Send Rollo a Private Message
Jag hade en 512 fram till för en månad sedan. Jag testade den aldrig mot något särskilt avslöjande förstärkeri, men tyckte ändå att den lämnade ett lite runt, spelglatt, tillbakalutat ljud utan särskilt mycket detaljer och rymd. Inte alls 'in your face'. Om detta inte är exakt vad du är ute efter är det nog, som SZR säger, ekonomiskt sundare att köpa DVD.
Ganska bra bygge, det enda problemet var (as always) displaybelysningen.
Edit: Den bangade inte för brända skivor heller, den lilla stridsvagnen.
Edited by - Rollo on 2003/02/24 15:19:53
Fred_J
Posted - 2003/02/24 :  18:39:43  Show Profile Send Fred_J a Private Message
Det här var en spelare där kvittot fanns kvar och det finns inga repor på den (från -96 el -97). Dessutom fick jag signalkablar med som såldes för 350:- på Hifiklubben. Som sagt så passar den stärkaren utseendemässigt också, vilket är viktigt. Ser maten god ut så smakar den bra så att säga :)
Det jag är ute efter är så varmt ljud som möjligt eftersom VH-1:orna låter lite väl "krispiga" med min nuvarande förstärkare. Förhoppningsvis så blir ljudet mjukare med NAD-förstärkaren och NAD-CD:n. Ett par stycken har beskrivit hur mycket dyrare förstärkare som driver VH-1:orna låter dåligt, medan NAD-stärkaren gav det rätta ljudet. Jag litar på dessa kommentarer.
Nu återstår det att se om CD:n förbättrar ljudet eller blir en svag länk i kedjan... Allt som mjukar upp ljudet är välkommet!
Denna sida genererades på 0.81 sekunder. Snitz Forums 2000
