 Onkyo TX-SR707 säljes/byte DAC med hörlursutgång
iMac
Posted - 2016/09/11 :  10:50:13  Show Profile Send iMac a Private Message
Onkyo TX-SR707 7.2 med fjärr, mick o manual. HDMI kortet utbytt på garanti. Säljes eller byte mot DAC med hörlursförstärkare eller Primare tuner, defekt inget hinder. 1500kr
Info:
THX® Select2 Plus Certified with THX Loudness Plus
#8226; DTS-HD Master Audio, DTS-HD High Resolution Audio, DTS-HD Express, Dolby® TrueHD, Dolby® Digital Plus, Dolby® Pro Logic® IIz Decoding
#8226; HDMI Version 1.3a to Support Deep Color;, x.v.Color, LipSync, Dolby TrueHD, DTS-HD Master Audio, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
#8226;Audio and 1080p Video Processing via HDMI (1 Front/5 Rear Inputs and 1 Output)
#8226;HDMI Video Upscaling to 1080p with Faroudja DCDi Cinema
#8226;Burr-Brown 192 kHz/24-Bit DAC
#8226;Two TI 32-Bit DSP Chips for Advanced Processing
#8226;Audyssey DSX (Dynamic Surround Expansion) for New Surround Channels
#8226;Audyssey MultEQ® to Correct Room Acoustic Problems and to Calibrate Speakers
#8226;Dual Subwoofer Pre Outs
#8226;175 W/Ch at 6 ohm, 1 kHz, 1 Channel Driven, JEITA
#8226;WRAT (Wide Range Amplifier Technology)
#8226;DTS-ES Discrete/Matrix, DTS Neo:6®, DTS 96/24, Dolby® Digital EX Decoding
#8226;DTS Surround Sensation® Speaker/Headphone Technology
#8226;Music Optimizer for Compressed Digital Music Files
#8226;RIHD (Remote Interactive over HDMI) for System Control
#8226;Double Bass Function
#8226;Direct Mode
#8226;Pure Audio Mode
#8226;Non-Scaling Configuration
#8226;7 Multichannel Pre Outs
#8226;6 Digital Inputs (3 Optical and 3 Coaxial)
#8226;Banana Plug-Compatible Speaker Posts
#8226;Powered Zone 2 and Zone 2 Line-Out for Playback in Another Room (Separate Source)
#8226;Bi-Amping Capability
#8226;Independent Crossover Adjustment for F/C/S/SB (40/50/60/70/80/90/100/120/150/200 Hz)
#8226;Video Output (Monitor)
#8226;2 Audio Inputs and 1 Output
#8226;Phono Input
#8226;RS232, IR (Input), and 12 V Trigger (Zone 2) Connectivity
Edited by - iMac on 2016/09/11 10:56:45
