 Tweak!!!
ud
Posted - 2003/02/15 :  21:53:38  Show Profile Send ud a Private Message
Hittade detta på http://www.tnt-audio.com/feedback/february03.html
Cryogenic tweaking :-)
Yesterday I put my ac-powercord in the refrigerator. This morning I pulled it out, let it dry for 5 minutes. Then I used cleaning-fluid (foam) you can buy for a couple of euros in any computer-shop to clean you p.c.
This stuff is very cheap and is anti-static at the same time. I cleaned the cable with some of this cleaning foam. Then I attached it to my power-amp.
The difference was AMAZING!! Much more 3-D. Much more stability, no wavering image anymore. More detail.
Bottom line: This hifi-thing is a strange thing. And it costs almost next to nothing.
Ur med bullarna och i med kablarna
Jan-Erik
Posted - 2003/02/16 :  09:46:18  Show Profile Send Jan-Erik a Private Message
Man slutar aldrig häpnas...
Är det någon på forumet som testat det än då??
Elektronik i all ära, men som jag brukar säga, inget lyfter ljudet som ett par riktigt bra kablar
