 *SÅLD*Strömkabel Referens Shunyata Anaconda Zitron
crion
Posted - 2014/11/04 :  19:56:56  Show Profile Send crion a Private Message
Shunyata Anaconda Zitron är förmodligen den mest kända referensströmkabeln. Denna modell är den senaste 2014 versionen för Svenskt Schuko vägguttag samt C19 IEC (stora slutsteg, strömrenare). Jag har kört den från vägg in i både Shunyata Hydra Triton och Hydra Talos strömrenare med utmärkt resultat. Men även stora referensslutsteg och andra referensströmrenare passar denna stömkabel utmärkt till.
The Anaconda model represents Shunyata Research's reference for design, measurement and test purposes. Outside of the world's most celebrated professional music studios and the most finely calibrated sound and music systems, the Anaconda represents only the promise of what is possible at the outer-reaches of the technology. The Anaconda holds a place as a reference-point for the industry, not as commercial success but as a product with no compromise and a single purpose; to showcase the startling performance effects of a technology fully realized. The Anaconda uses VTX (hollow-core wire geometry) conductors. The new AC connectors are developed with pure copper, the CDA-101 CopperConn.
APPLICATIONS
Due to theAnaconda's top of the product range cost and performance, it must be considered an exclusive product for only the world's finest professional, critical and consumer systems. TheAnaconda will offer dramatic performance improvements used with literally any system component. Even a single seven-gauge Anaconda placed on a critical source component, amplifier, Hydra or other power distributor will deliver an increase in dynamics, low-level resolution and clarity the likes of which no other power cord or exotic power conditioners can offer.
VTX Geometry Conductors
Shunyata Research has developed what might be the world's perfect power conductor geometry. VTX wire geometry simulates a hollow conductor, which minimizes inherent inductive reactance and skin effect, improving DTCD instantaneous current propagation.
CDA-101 Copper
CDA 101 copper is the highest purity copper on the metals market. It comes with papers that prove its authenticity. This is the only type of copper that Shunyata Research uses in its electrical products, from signal cables to power cords and power conditioners.
ALPHA CRYO Process
Shunyata Research cryogenically treats all wire and electrical contacts used in the production of its signal cables. A state-of-the-art computer controlled chamber is used to lower the temperature of the contents to -320 degrees fahrenheit. The exclusive, Shunyata Research developed, Alpha Cryogenic Process uses a proprietary combination of gases to enhance the cryogenic treatment.
SHUNYATA CopperCONN#8482; CONNECTORS
Pure Tellurium Copper Base Metal
Superior Contact Grip
Alpha Cryogenic Treated
Anaconda Zitron Specs
FEATURES CopperCONN#8482; CONNECTORS AC & IEC connectors
CDA-101 cryogenic copper conductors
Unrivaled Shunyata Research Craftsmanship
7 AWG Coincident Concentric Conductors
VTX Geometry
MAINS CONNECTORS Schuko (EURO)
STANDARD LENGTH
- 6.0 feet (1.75M)
Produktionsår: 2014
Edited by - crion on 2015/03/16 22:10:26
