 Montering av tonarm
divander
Posted - 2003/02/12 :  08:47:03  Show Profile Send divander a Private Message
Jag har ett litet problem med montering av en tonarm. JAg har en Opus3-spelare och en RB300-arm. Hålet för tonarmen på skivspelaren är 29mm, men jag har för mig att RB300 behöver 23mm. Hur monterar jag armen i hålet som är för stort? Är det någon som har något bra förslag?
Oops! I did it again
Daniel
Posted - 2003/02/12 :  09:48:50  Show Profile Send Daniel a Private Message
Hej Divander.
Har du kollat in de olika VTA-justeringshylsorna som finns. Här nedan står det om OriginLive.
Daniel
Threaded vta adjuster
We offer 2 types of vta adjuster for the rega arm - the first called the "threaded vta adjuster" which will suit all decks. It is simply a thin threaded collar which threads onto the rega arm base. As the collar is rotated up and down it raises and lowers the height of the arm. You need a mounting hole of 24mm diameter or over (if your armboard is less than 11mm thick please let us know as we will need to add a spacing washer to your order) - this adjuster works well on the Linn LP12. Fortunately Rega decks and many others have this diameter already as the hole for the Rega arm is toleranced sufficiently oversize. The threaded vta adjuster initially raises the height of the rega arm by 2mm due to the top flange thickness - it can then raise the arm further by approx 10mm depending on the thickness of your armboard. This adjuster is included as standard with the Silver 250 & Silver Taper tonearms, so does not need to be purchased seperately..
Price £25 GBP ( 21.28 GBP Export price)
