 Onkyo TX-NR708 *såld*
hjort
Posted - 2013/07/30 :  11:34:43  Show Profile Send hjort a Private Message
Nypris sänkt från 7.995:- till 4.995:- säljes för 2.500:- 2.000:-
Uppdaterad med senaste mjukvaran.
Kan styras med smartphone.
Power and Processing:
110 watts x 7 into 8 ohms (20-20,000 Hz) at 0.08% THD
THX® Select2 Plus#8482; certification for a guaranteed, theater-quality listening experience
Dolby® TrueHD, DTS-HD#8482; Master Audio, Dolby® Digital Plus, DTS-HD#8482; High Resolution Audio, Pro Logic® IIz
analog-to-HDMI video upconversion (up to 1080p) with Faroudja DCDi Cinema#8482; video processing
Audyssey MultEQ six-point auto speaker calibration (microphone included)
Audyssey DSX processing for enhanced surround sound height or width effects using additional front speakers
Audyssey Dynamic Volume mode to maintain steady listening levels
Audyssey Dynamic EQ#8482; for fuller surround sound at lower volumes
Digital Music Options:
streams music from your PC and the Internet (broadband connection required)
iPod®/iPhone® integration (video playback requires optional Onkyo UP-A1 dock)
SIRIUS satellite radio capable (requires SIRIUS subscription and optional SiriusConnect#8482; home tuner kit)
HD Radio ready (requires optional Onkyo UP-HT1 tuner)
DLNA (Digital Living Network Alliance) certified to ensure optimal compatibility with other network-enabled equipment
Audio Performance Features:
high-current amplifier design with massive power transformer
192kHz/24-bit Burr-Brown digital-to-analog converters for all channels
direct mode switches off unnecessary circuitry to provide cleaner sound
back surround speaker channels re-assignable for bi-amping compatible front left and right speakers
Music Optimizer function enhances the sound quality of compressed music files
Connections:
1080p-compatible HDMI switching: 7 in, 1 out (including 1 front-panel input)
HDMI version 1.4 with support for 3D video, Audio Return Channel, Deep Color, x.v.Color, auto lip-sync, and HDMI-CEC
Audio Return Channel function receives digital audio signals from a compatible HDTV's tuner via HDMI
component video switching (2 in, 1 out)
analog RGB video input (D-sub, 15 pin) for connecting a PC
digital audio inputs: 2 optical and 3 coaxial
5 audio/video inputs, including:
1 front-panel input with composite video
4 rear-panel inputs with composite video
1 audio-only input
phono input
Ethernet port for music streaming from a PC network
2 audio outputs for powered subwoofers
1 front-panel minijack audio input for connecting a portable player
1 pair of main speaker outputs
Edited by - hjort on 2013/08/26 20:34:07
Larsho
Posted - 2013/08/01 :  07:13:06  Show Profile Send Larsho a Private Message
Var i landet finns den
hjort
Posted - 2013/08/01 :  13:18:20  Show Profile Send hjort a Private Message
Den finns i Göteborg men kan skickas
Tobbe_L
Klubbmästare i AÖ
Posted - 2013/08/06 :  07:18:10  Show Profile Send Tobbe_L a Private Message
Nu har du ett PM
Jag är inte dum....
