 NTSC Version.....................
kme
Musik-Harry 2005
Posted - 2013/01/17 :  10:03:52  Show Profile Send kme a Private Message
NTSC Version format på dvd film är det detta format som gäller i sverige, någon som vet...............
Listen: Music Tip by Kurt.Välj Bland Olika Artister På: http://sweetspotforum.forum24.se/sweetspotforum-about92-0.html Klassiskt på: http://sweetspotforum.forum24.se/sweetspotforum-about102-0.html
http://www.youtube.com/watch?v=AlLpdWbSevc
http://www.youtube.com/watch?v=YvEccfdw_kU
Posted - 2013/01/17 :  10:07:34  Show Profile  Visit AlfaGTV's Homepage Send AlfaGTV a Private Message
Nej, producerat för Region 2 bör betyda PAL...
The three differences between NTSC discs and PAL discs are:
1) Picture size and pixel aspect ratio (720x480 vs 720x576),
2) Display frame rate (30 vs 25),
3) Video from film is usually encoded at 24 frames/sec. but is preformatted for one of the two display rates. Movies formatted for PAL display are usually sped up by 4% at playback, so the audio must be adjusted accordingly before being encoded.
Din spelare brukar vanligen hantera båda formaten, och även din TV om du inte sitter på våldsamt antika saker...
MVH /Micke
