 SÅLD - MiniDSP 2x8 inklusive plugg
UrSv
Posted - 2012/12/18 :  13:34:07  Show Profile Send UrSv a Private Message
Säljer mitt MiniDSP 2x8 inklusive plugin. MiniDSP 2x8 är ett digitalt delningsfilter som kan konfigureras på ett stor antal sätt med hjälp av plugin som stödjer olika funktioner.
http://www.minidsp.com/products/minidspkits/2-x-in-8-x-out
SEK 2000 eller bud inkl frakt
Sampling frequency 96kHz
Algorithm resolution Double precision filters (56bits resolution)
Input mute/select Click-less input mute per channel and input selection
Digital gain Fader gain control from #8211;80 to 0dB
Input/ Output meters Monitoring signal from #8211;80dBFS to 0dBFS - High refresh rate
Low & High Pass filter types
Butterworth up to 8th order (6 to 48dB/oct)
Linkwitz-Riley up to 8th order (12 to 48dB/oct)
Bessel - 2nd order - Bypass per filter
Frequency: 10Hz to 20kHz in 1Hz increments
Parametric Equalizers (Peak/Low&High shelve)
5 PEQ bands per input, 5 PEQ bands per output
Frequency: 10Hz to 20kHz, 1Hz increments
Gain: 0 to 16dB, 0.1dB increments
Q: 0.5 to 50, 0.1digit increment
Type: Peak of Shelf (low/high) & Per-band bypass feature
Delay (time alignment) Up to 9ms per channel (3m) in 0.02ms increments
Analog Outputs only
Polarity Invert polarity 180degree per channel
Output mute Individual output mute
Master output gain Analog potentiometer control master output digital gain
fader from #8211;80 to 0dB. Disabled if no pot connected.
Mixer Central mixer for 4 x 10 cross-point configuration (ON/OFF)
Inputs/Outputs Inputs: Up to 2 analog inputs, up to 2 digital inputs (I2S)
Outputs: Up to 8 analog outputs, up to 2 digital outputs
DSP Audio flow chart diagram
Software features
* Extensive set of audio algorithms
* Live tuning, hear changes real time
* Channel linking to synchronize settings of two channels PEQ/Crossovers)
* Save/Load configurations
* Up to four preset configurations stored
* Extensive plotting capabilities
* Plug & Play setup requires no driver
* Custom Input/Output labels
* Free Un-limited Upgrades
Applications
* Active loudspeaker processor
* Custom amplifiers
* Car audio processor
* Small PA processor
* Custom Pro Audio boards
Edited by - UrSv on 2013/04/10 21:13:40
