tian
1555 Posts |
Posted - 2010/01/06 : 21:28:53
Tjenare.
Har detta PA steg till salu.
Jaytec PAE-1600 V2.0 Output capacity: 2 x 600W, 4 Ohm Features :
Separate amplifier circles for channels A and B High-speed exhaust Large, oversized cooling fins Overload and short-circuit protection Ground/lift switch against interferences Outputs: large, massive c-clamps, PA pro speaker- cable Inputs: RCA jacks, 6,3 mm jacks
Technical data
1200 watt PA power amplifier Output capacity: 2 x 260W, 8 Ohm Output capacity: 2 x 600W, 4 Ohm Output capacity: 1 x 520W, 8 Ohm Frequency range: 20 Hz - 50 kHz Dimensions: 482 x 94 x 358 mm Weight: 10.6 kg
Utrustad med vanliga högtalarutgångar och rca ingångar.
Pris: 1000 SEK POK
PM:A om det är intressant
