 Audio Pro A4.14
regent8
Posted - 2003/01/13 :  23:36:08  Show Profile Send regent8 a Private Message
Hi, I am curious about a sweidsh speaker that I've rquired.
Is it possible to improve it? I've read somewhere that there are a couple of modifications that can even improve this speakersystem.
Does anyone know wabout it?
Aran
avr7000
Harry-vinnare 2004
Posted - 2003/01/14 :  01:04:09  Show Profile Send avr7000 a Private Message
The modifications that I can remember that I have heard of is:
Wooden quarter-stip to fill up the "step" around the baffle...
- to minimize difraction.
deaden midrange plastic "box" by applying "bitumen rubber" on it...
Also check the status of the foam surround on the woofers, the foam will eventually become rotten and fall off... don't worry, the foam can relativly easy be replaced.
The Sipe tweeter is to my knowlage discontinued but I think a replacement driver is manufactured by Sinus...
/Stefan
Mina pryttlar
http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=12665
Edited by - avr7000 on 2003/01/14 19:25:23
Mattepatte
Ej medlem längre
Posted - 2003/01/14 :  21:06:31  Show Profile Send Mattepatte a Private Message
I find it hard to believe that Sinus has good replacement units for the italian Sipe tweeters.
But if you need a pair of Sipe tweeters as well as a pair of the midrange units in good condition, I could sell mine at a decent price.
I think the mod also included some bitumen damping of the bass chamber.
The woofers can be bought at www.hifikit.se (each about $70)
