 Passivt försteg- AudioSynthesis Passion - SÅLD
Posted - 2009/06/06 :  21:17:10  Show Profile Send Micke Y a Private Message
Det här är ett verkligt fint passivt försteg som jag säljer. Det har alla de finaste delarna och ser snyggt ut, eller hur?
31 lägen och Vishay motstånd rakt igenom.
3 stereo line inputs, tape output, main listen out and mute facility
- Tape output may be used as a Direct In, by-passing all input switching
- Stereo, 31-step, all Vishay attenuator, 1.5dB & low level 6dB steps
- Less than 0.05dB error in Left to Right tracking and individual step accuracy
- Absolute simplicity - a classic 'L' pad only 2 Vishay Bulk Foil resistors are ever in the signal path at any one time
- Signal and ground of all inputs are switched for total source isolation
- Coin silver self-wiping switch contacts
- WBT connectors, Teflon insulated, 24 carat gold plating & isolation
- Pure silver (>99.99%) & Teflon used for all internal wiring
- Fully comprehensive 2 year guarantee on components & workmanship
- Size (w x h x d): 110mm x 65mm x 130mm
- Weight including packaging: 1.9kg
Investering: 4.000:- 3.000:-
zapzolute@yahoo.se
eller pm
Finns i Stockholm
Edited by - Micke Y on 2009/08/09 20:14:01
