| Author |
Topic  |
reVintage
3454 Posts |
Posted - 2009/05/14 : 17:54:33
Orkar inte översätta, så jag kör samma text som i min tråd på diyaudio/passlabs:
Lately there has been quite a few threads covering the work of OH Schade 1938, http://www.clarisonus.com/Archives/TubeTheory/Schade%201938%20Beam%20Power%20Tubes.pdf . He showed how a tetrode could get triode characteristics with the help of what he called "inverse-voltage feedback". While working as a triode the efficiency of the tetrode was still kept.
On the left is a tube SE in accordance to his suggestion. It has the same output impedance and distortion characteristics as if it had been triode-strapped but twice the output power! On the right the output device is substituted by a common MOSFET that according to Schades suggestion is feedbacked ca 20dB.
Seeing any similarity with a Zen ?
By the use of an IT there is a better chance of getting improved HF-bandwith. The example sims with a -3dB point in the region of 100kHz.
A MOSFET has pentode-like characteristics.
With shunt-feedback(inverse-voltage feedback) applied they change to triode-like.
But this is old news for the most of you !
mvh Lars "Back To Basics" Bygger reVintage Amps, www.revintage.se Sur man med svart själ! |
Edited by - reVintage on 2009/05/14 17:55:16 |
peranders
2456 Posts |
Posted - 2009/05/14 : 19:17:33
| Bygger du nåt, inte bara simulerar? |
/Per-Anders eller P-A |
reVintage
3454 Posts |
Posted - 2009/05/14 : 19:33:21
| Hurså? |
Lord
1020 Posts |
Posted - 2009/05/14 : 19:36:45
Nä, reVintage är en simulant, det ser bara ut som om han gör någonting  |
En bit tråd blir inte mer antenn bara för att du kan ansluta den till radion Min anläggning |
FForsman
2604 Posts |
Posted - 2009/05/14 : 20:41:44
| Spännande, lödkolven är redan varm! |
Ett forum blir till det som medlemmarna bidrar med. Skriv! |
reVintage
3454 Posts |
Posted - 2009/05/14 : 20:44:59
Jag är en slö f-n. Hade 3 konstruktioner med på Gbg-mässan men hade bara lött en själv  !
Åter till ämnet, några funderingar kring min senaste kretslösning? |
8590 Posts |
Posted - 2009/05/14 : 20:55:42
Förstår inte riktigt biaskretsen i grusvarianten. Har förresten haft tankar på liknande återkoppling runt mina RCA 808:or den dag jag äntligen kommer till skott och bygger med dem. |
reVintage
3454 Posts |
Posted - 2009/05/15 : 08:53:50
quote: Förstår inte riktigt biaskretsen i grusvarianten.
Den är väl helt självklar! Ställ bias-spänningen så att du får rätt tomgångsström. I detta fall hamnar kanske gatespänningen någonstans mellan 4,5 och 5V. Du kan ju inte ändra motstånden eftersom de utgör motkopplingsslingan.
Bry dig inte om komponentvärdena, de är fejkade för att man inte ska kopiera rakt av.
Faktum är att jag tänkte mata med 13.2V SMPSfrån Kjell&Co ! Uteffekten blir då ca 5W vid 1%THD. Som synes är inte övertonsspektrat lika jämnt fallande som hos en triod men det ser helt OK ut.
quote: Har förresten haft tankar på liknande återkoppling runt mina RCA 808:or den dag jag äntligen kommer till skott och bygger med dem.
Undrar om det är en bra idé? Det är ju trioder, iofs med pentodlika kurvor. Konceptet är för pentoder. Men det är ju snygga rör . |
Edited by - reVintage on 2009/05/15 12:19:10 |
8590 Posts |
Posted - 2009/05/15 : 13:03:55
quote: Den är väl helt självklar!
Funderar bara lite kring behovet av batteri när man ändå har en positiv spänning och en spänningsdelare ner till gaten tillgängligt.
quote: Men det är ju snygga rör
Exakt, och det är banne mig den enda orsaken till att jag vill bygga med dem! Ur praktisk synvinkel är de på alla tänkbara sätt värdelösa... Funderar också på att använda en triod istället för två motstånd i återkopplingsslingan, blir nån STC-variant då. |
reVintage
3454 Posts |
Posted - 2009/05/15 : 13:32:17
quote: Funderar bara lite kring behovet av batteri när man ändå har en positiv spänning och en spänningsdelare ner till gaten tillgängligt.
Iom att spänningsdelaren har ett förutbestämt värde, får man hjälpa den lite på traven .
En tänkbar variant är att ha en trimmer under R3 med en avkopplingskondensator till jord. Men med högre matningsspänning blir spänningen negativ. |
Edited by - reVintage on 2009/05/15 13:38:59 |
ludo
1196 Posts |
Posted - 2009/05/15 : 17:25:11
quote: Som synes är inte övertonsspektrat lika jämnt fallande som hos en triod men det ser helt OK ut.
reVintage
Alltid kul med lite nytänkande här på forumet! Men... det ser inte alls OK ut ... just den här kopplingen av överonsspektrat att dömma kommer inte att låta något vidare bra. Det kommer att låta hårt, vasst och "orent". De udda övertonerna är mycket höga till amplituden och sträcker sig långt (alldelles för långt) på frekvensskalan. Det är vad min efrarenhet säger. Går det att "få ner" övertonsspektrat både i amplitud och frekvens (så att h7/h9 hamnar under brusgolvet)?
reVintage
3454 Posts |
Posted - 2009/05/15 : 18:45:47
Ludo, Av ditt svar att döma så tror jag inte att du är kapabel att bedöma hur det kommer att låta . Men du kanske vaknade på fel sida igen .
Övertonsspektrat är nämligen näst intill likadant som den triodkopplade varianten. Dessutom är det något snyggare än Pass Zen-förstärkare.
ludo
1196 Posts |
Posted - 2009/05/15 : 19:17:12
Ville bara anmärka på att en sån lång svans av så "höga" övertoner bådar inte gott. Bara det. Inget personligt ... bara en fundering kring hur övertonsspektrat ser ut.
Och som sagt ... alltid kul att se nya kretslösningar. |
Topic  |
