 B&W N805 Signature
Jadde
Posted - 2002/07/16 :  09:51:52  Show Profile Send Jadde a Private Message
B&W has announced a new Signature version of its Nautilus 805 standmount speakers, following on from the launch of the big Signature 800 speakers last year.
The new speakers are finished in either Bird's Eye or Tiger's eye wood veneers, the finish contributing a significant part to the price, which is £2250 against the £1800 of the standard N805s, which will continue to be sold. But the changes are more than skin-deep: the speakers use an improved tweeter, with a raised top-end cut-off point of 50kHz. Distortion at these high frequncies has been minimised by silver-plating the magnet centre pole.
The mid/bass unit has also been adjusted to give a faster and tighter response, principally by the adoption of a magnet some 40% bigger than that in the standard N805. An aluminium centre 'bullet' is fitted instead of the standard speaker's plastic piece, thus cleaning up the upper midrange, and the crossover has been extensively upgraded.
The speakers are in the shops now.
What goes around comes aroun
Jadde
Posted - 2002/07/16 :  09:52:55  Show Profile Send Jadde a Private Message
http://www.soundcompany.ch/content.asp?spage=3&acode=21
Hur lägger jag upp bilder här? "Insert image" OK, men hur?
lindvall
Posted - 2002/07/16 :  11:22:27  Show Profile Send lindvall a Private Message
lindvall
Posted - 2002/07/16 :  11:24:37  Show Profile Send lindvall a Private Message
Genom att högerklicka på bilden och sen kolla på "egenskaper" och sen klistra in den adressen (URL) som visas i rutan som kommer upp. Alltså inte adressen som står i webbläsarens fönster, utan själva "bildadressen".
Förtydligande: Sätt in den adressen mellan img och /img så kommer bilden fram till allmän beskådan
Edited by - lindvall on 2002/07/16 11:26:2
platypus
Posted - 2002/07/22 :  23:11:52  Show Profile Send platypus a Private Message
Hmm ser kul ut... måste testa dessa över pris högtalare först....lite väl dyra eller?
platypus
Posted - 2002/07/22 :  23:22:04  Show Profile Send platypus a Private Message
Vad finns som är i samma prisklass/lika bra
platypus
Posted - 2002/07/22 :  23:24:46  Show Profile Send platypus a Private Message
Och inget Qrs Fenomen....tack...vet hur qrs låter....
Neptunus Bra Saturnus helt ok resten sisådära...lol
