 Extern DAC .....
Creative Audio
Posted - 2009/02/06 :  14:13:55  Show Profile  Visit Creative Audio's Homepage Send Creative Audio a Private Message
music hall
dac25.2
Today an increasing number of music lovers are buying, storing, and listening to music through their computer, media server, or personal music player (iPod). Many are also digitally distributing their music using a Sonos, Squeezebox, or one of a host of digital music distribution systems available on the market. This is a great way to explore and appreciate music but generally its done at the expense of sound quality. Until now, music lovers have been forced to rely on the inferior digital-to-analog converters (DACs) and sounds cards contained in those devices, and as a result, their musical enjoyment has dramatically suffered. We designed the dac25.2 to directly address this problem and to significantly improve the sound quality of the music played on these systems.
By uniting a state-of-the-art digital-to-analog converter with a tube output we produce the clarity and precision of a 24bit DAC with the warm rich open sound people love of tubes. The dac25.2 has 4 digital inputs which can accept any coax (s/pdif), optical, XLR, or USB digital input from an iPod transport, computer, media server, Sonos, Squeezebox, CD/DVD in stereo transport, or music halls own cd25.2 compact disc player, and it will output two channel stereo analog.
The dac25.2 features the latest Texas Instruments (formerly Burr-Brown) PCM1796 24bit, 192kHz, advanced segment, stereo audio digital-to-analog converter. This processor features 123dB dynamic range, an 8 x oversampling digital filter, and just 0.0005% THD. The dac25.2 upsamples to either 96kHz or 192kHz, which is user selectable on the front panel. To achieve the best sound, we use an advanced asynchronous reclocking and anti-jitter control system upstream of the PCM1796 DAC. For this system, we are using the Philips 74HC574 in conjunction with the Ti SRC4192 Asynchronous Sample Rate Converter, whose master clock is a high precision active crystal oscillator. The dac25.2 also features a large, high current oversize power supply. A headphone output is provided for convenient personal listening.
Features
Electro-Harmonix 6922 tube output
Ti PCM1796 24bit, 192kHz DAC
Ti SRC4192 Asynchronous sample rate converter w/high precision active crystal oscillator master clock
User selectable 96kHz or 192kHz upsampling
Sophisticated asynchronous reclocking and anti-jitter control system
4 digital inputs: coax (s/pdif), optical, XLR, or USB
2 Gold-plated outputs: single ended (RCA), balanced (XLR)
Headphone output with adjustable volume control
Large high current oversize power supply
Thick brushed-aluminum fascia and solid chassis
110v/220v voltage selectable transformer
Detachable power cord
Specifications
THD+N: <0.04% Tube out (1KHz)
<0.0015% Balanced out (1KHz)
Output level: 2.0V
Frequency response: 2Hz~20KHz +/-0.2dB
SNR: >110dB
Power dissipation: <30W
Dynamic range: > 120dB (24 bit)
> 96dB (16bit)
Crosstalk: <-110dB
Operating temperature: 0 ~ 40#8451;
Headphone output level: 4V max
Headphone output resistance: 0.3 ohm
Power supply: AC115V/60Hz - 230V/50Hz
Investering ca 6595 kr idag ......
http://www.creative-audio.se
Edited by - Creative Audio on 2009/02/07 15:02:11
johmi
Posted - 2009/02/06 :  19:38:36  Show Profile Send johmi a Private Message
Intressant! Om jag förstår texten rätt så är det rör på utgången! Vad skiljer den mot cd25.5's digital- och analogdel (den har ju inte rör).
/Mikael
BosseBula
Posted - 2009/02/06 :  19:39:43  Show Profile Send BosseBula a Private Message
Finns det möjlighet att provlyssna hemma hos sig?
Min medlemstråd
Snoop
Medlem, HiFi Norr
Posted - 2009/02/06 :  19:47:24  Show Profile Send Snoop a Private Message
verkar lovande.
Moderator på Minhembio
