 Nyheter från Ayon!
Just Audio Magic
Posted - 2008/11/05 :  22:44:16  Show Profile  Visit Just Audio Magic's Homepage Send Just Audio Magic a Private Message
Nyheter från Ayon, bland annat en integrerad förstärkare och ett par högtalare;
Triton
Class of Operation Triode or Pentode mode
Tube Complement 8x KT88 or KT90, 6x 12AU7
Load Impedance 4 & 8 Ohms
Bandwidth 8Hz -70kHz
Output Power / Pentode mode 2 x 110 Watt
Output Power / Triode mode 2 x 65 Watt
Peak Output Power / Pentode mode 2 x 140 Watt
Frequency Response 15 Hz - 35 kHz / 0 dB
Frequency Response 10 Hz - 60 kHz / -2.5 dB
Input Impedance at 1 kHz 100K Ohm
Input sensitivity ( full power ) 260mV
S/N ratio at full power 98 dB
Hum 0,003 V
NFB 0dB
Volume Control Potentiometer
Remote Control Yes
Inputs & Outputs 4 x Line IN, 1 x Direct IN, 1 x Pre Out
Dimensions (WxDxH) cm 50x40x25 cm
Shipping dimensions (WxDxH) cm 78x68x53 cm
Weight 44 kg
Crane
System - IPRCS 3-way
Inverted parabolic resonance
correction system
Cabinet Resonance optimized
Driver Complement 1" Revelator - Ring Radiator Tweeter
6,5" Ceramic Midrange
2 x 9" Ceramic Woofer
Impedance 6 Ohm
Sensitivity (1W / 1m ) 92 dB
Recommended Amp Power 20 - 300 Watt
Frequency Response 28 Hz - 47 kHz / -3 dB
Single-Wire Terminal WBT
Crossover design - CMFIC Crossover magnetic field interaction control
Internal Wire - Ayon Audio Harmonically signal flow distance wiring
Recommended connection (+) for tube amps (4, 8, 16 Ohm) 8 Ohm
Dimensions (HxWxD) each 144x32x55 cm
Weight, each 68 kg
Micke äger och driver Just Audio Magic tillsammans med Jenny !
www.justaudiomagic.se
Just Audio Magic
Posted - 2008/11/09 :  02:07:42  Show Profile  Visit Just Audio Magic's Homepage Send Just Audio Magic a Private Message
CD-2, mellanmodell mellan CD-1 och CD-3!
