 Ypsilon - DEMO!
Just Audio Magic
Posted - 2008/09/04 :  11:08:03  Show Profile  Visit Just Audio Magic's Homepage Send Just Audio Magic a Private Message
Nu har vi äran att presentera Ypsilon på den Svenska marknaden!
Först ut är deras förförstärkare PST-100 och monoblock SET-100
Färglöst?
För de seriöst intresserade kan vi ordna en rättvis demo
310 000 :-
549 000 :-
Lite info om PST-100;
Bandwith: 5 - 100 000 hz (-3 db
Output resistance: 150 ohm
Input resistance: 50 Kohm
Gain: x10 (20 db)
Dimensions: H180 x B400 x D410 mm
Weight: 25 kg
"The active gain stage is based on a single triode. It is perfectly executed. Copper foil, paper in oil signal capacitors with tube rectification and choke regulation with custom made pure silver wire is the ideal environment for the triode to perform its best. Instead of using the attenuator at the input and then the active gain stage, transformer coupled, we designed the attenuator in such a way that it could be placed at the output as the output transformer. It can't get any simpler than that. With minimum signal path : one triode , one transformer, we achieved on having maximum gain of 20db, output
impedance around 150 ohms in most taps and maximum attenuation of 48 db"
Lite info om SET-100;
Output power before clipping: 120 watt (8 ohm)
Bandwith: 5 - 80 000 hz (-3 db)
Output impedance 1 ohm
Input impedance: 100 Kohm
Gain: 34 (30 db)
Dimensions: H610 x B240 x D672 mm
Vikt: 80 kg
"The first stage is a high transconductance double triode selected for its sonic apabilities and reliability. It is powered by a separate power supply with tube rectification and choke regulation. The triodes are not paralleled directly since this produces a harsh sound, but are mixed in the second stage without one "seeing" the other. This method of interconnection is patent pending....
Compared with state of the art single-ended triode amplifiers it is more direct sounding, musical, with more instrument body , lower frequency extension, frightening dynamics and most of all magically three dimensional. Any comparison between SET-100 and all types of push-pull amplifiers is like comparing true with fake"
Micke äger och driver Just Audio Magic tillsammans med Jenny !
www.justaudiomagic.se
Edited by - Just Audio Magic on 2008/09/10 13:32:59
Just Audio Magic
Posted - 2008/09/10 :  13:21:55  Show Profile  Visit Just Audio Magic's Homepage Send Just Audio Magic a Private Message
För de som är intresserade kommer vi att ha en demo tillsammans med distributörerna innan detta årets slut, mer exakt datum kommer vi till !
Intresserade hör gärna av sig då vi har ont om platser!
Edited by - Just Audio Magic on 2008/09/10 13:22:39
