 Nytt högtalarmärke på den Svenska marknaden?
Just Audio Magic
Posted - 2008/07/13 :  11:38:00  Show Profile  Visit Just Audio Magic's Homepage Send Just Audio Magic a Private Message
Kallbo;
RM30 finns i två versioner;
M och C -> "RM30 is 50 cm (20") deep, but can be placed directly against a back wall if needed. The FST, Soundcoat and 10" Megawoofer are all standard. M and C versions are exactly the same except for the M's sidefiring woofers. The large cabinet of the C version provides good quality bass flat to 39 Hz from the four 16 cm WCF woofers. The M version cuts off at 32 Hz. The RM30 uses three 2.4 Ohm midrange panels wired in series. The FST is at the top of the column. The C version is a true line source, the M series is a slight departure with its side-firing woofer. The active 16 cm is a specially developed WCF 16 cm Megawoofer. They offer higher power handling, cleaner sound and have the ability of not bottoming out no matter how hard they are driven."
C -> 35 995 :-
M -> 38 995 :-
MLS kabinet -> 3995 :-
Auricaps -> 6595 :-
TRT Dynamicaps -> 11 995 :-
Bass: - 25 cm (10") WCF Megawoofer bass, 2x 16 cm (6") WCF midbass, 2x 16cm (6") Passive Radiators
Mid: - three rectangular 10 x 20 cm (4 x 8") Neo ribbons, 280 Hz - 6.9 kHz
Treble: - FST, 6.9 kHz - 30 kHz
Impedance & Sensitivity: - 4 Ohm (3.6 min.) 93 dB/1W/1m
Power handling: - 400W rms / 4 Ohms, 20 W min.
Frequency response: - 32 Hz - 25 kHz +0/-3 dB
Dimensions & Weight: - 122H x 18W x 49D cm, 50kg (48"H x 7"W x 19"D cm, 110 lbs)
Output levels and distortion: - max. 1% THD fullrange / 1W, max. 115+ dB SPL/1m
Finishes: - standard lite oak, dark oak, MLS rosewood, macassar ebony. Optional MLS piano black
Stereo Times 2004 -> http://www.stereotimes.com/speak091204.shtml
Positive feedback 2004 -> http://www.positive-feedback.com/Issue16/vmpsrm30.htm
Stereo Times Most Wanted List 2005 -> http://www.stereotimes.com/mw2005d.shtml
CES 2006 reports -> http://www.vmpseurope.com/r-CES06.htm
AudioAsylum 2006 -> http://www.audioasylum.com/cgi/m.pl?forum=speakers&n=239783&review=1
Positive feedback 2007 -> http://www.positive-feedback.com/Issue30/emm.htm
Micke äger och driver Just Audio Magic tillsammans med Jenny !
www.justaudiomagic.se
Edited by - Just Audio Magic on 2008/07/13 11:45:44
Just Audio Magic
Posted - 2008/07/13 :  11:43:04  Show Profile  Visit Just Audio Magic's Homepage Send Just Audio Magic a Private Message
iroise;
Ber om ursäkt för det!
Här kommer alla priserna på VMPS;
626R FST -> 19 995 :-
RM2 FST -> 30 995 :-
RM30C -> 35 995 :-
RM30M -> 38 995 :-
RM40 FST -> 49 995 :-
RM V60 -> 88 995 :-
RM/X -> 148 995 :-
STIII/SRE -> 218 995 :-
OcA
Posted - 2008/07/24 :  11:50:45  Show Profile Send OcA a Private Message
Läste på VMPS sida att man kan beställa dem som kit också. Något som ni kan ombesörja och vad blir pengen då?
Vore även trevligt med priser på deras subbar som ser riktigt intressanta ut!
Just Audio Magic
Posted - 2008/07/24 :  14:45:47  Show Profile  Visit Just Audio Magic's Homepage Send Just Audio Magic a Private Message
OcA;
Priser på VMPS basar!
Dedicated subwoofer -> 8995 :-
Original subwoofer -> 9995 :-
215 subwoofer -> 12 795 :-
Larger subwoofer -> 16 795 :-
Very solid subwoofer -> 24 995 :-
Very large array -> 45 059 :-
Gissar på att du läst prestanda o vikter på deras basar??
När det gäller deras så kallade "kit" får jag återkomma efter jag pratat med Dubravko!
Just Audio Magic
Posted - 2008/07/24 :  16:02:15  Show Profile  Visit Just Audio Magic's Homepage Send Just Audio Magic a Private Message
OcA;
Ang kits så är det enbart möjligt för kunder i Amerika, detta för att bland annat frakt gör att det inte blir ekonomiskt
OcA
Posted - 2008/07/29 :  09:53:02  Show Profile Send OcA a Private Message
Ok! Tack för infon!
Era priser är riktigt bra på dessa högtalare om man jämför med övriga europapriser, bra jobbat!
När finns de för demo?
Just Audio Magic
Posted - 2008/07/29 :  17:22:54  Show Profile  Visit Just Audio Magic's Homepage Send Just Audio Magic a Private Message
OcA;
Finns ingen anledning att ha högre priser än vad som är nödvändigt, pengar ska inte vara det som prioriteras när det gäller denna branchen tycker jag.
Första demo är osäker då vår 1 månad gamla Lukas tar mycket tid nu :)
