 Conductor - Audio Valve
Just Audio Magic
Posted - 2008/05/02 :  16:25:52  Show Profile  Visit Just Audio Magic's Homepage Send Just Audio Magic a Private Message
Ny förförstärkare från Audio Valve i världsklass!
Separat nätdel och en 2,1" stor färgdisplay
Dual chassis with separate power supply
Dual mono circuit design, including power supply
Real symmetric input/output for negative/positive signal phase for both channels
No feedback loop
Input impedance 47kOhm
Output impedance 300 Ohm
Bandwidth 5Hz #8211; 200kHz
Gain 14dB
Input connectors: 2 x 6 XLR and 2 x 6 RCA terminals
Output connectors: 2 x 2 XLR and 2 x 2 RCA terminals
Valves: 4 x 6H30 (6N6P) and 4 x 6922
Manual operation and remote control
Mute and standby functions
Memory volume control for each input with 6-section analog potentiometer
Microprocessor-controlled with 2.1#8221; color graphic display
Power consumption: 150VA
Dimensions amplifier: 480 x 140 x 380 mm
Dimensions power supply: 480 x 80 x 380 mm
Weight: 25 kg (combined)
93 995 :-
Micke äger och driver Just Audio Magic tillsammans med Jenny !
www.justaudiomagic.se
