 Bösendorfer + McIntosh
OJCO
Posted - 2008/04/07 :  11:42:37  Show Profile  Visit OJCO's Homepage Send OJCO a Private Message
Denna vecka kommer vi att spela på anläggningar med högtalare från österrikiska Bösendorfer och elektronik från McIntosh.
Från Bösendorfer har vi följande:
VC 2
Bösendorfer's mid-sized floor standing loudspeaker. Two-way system with one treble speaker, two bass drivers /mid-range speakers and two Acoustic Sound Boards.
frequency response 31 - 25,000 Hz (±3 dB)
crossover frequencies 130 Hz*; 2.9 kHz
power rating 90 watts
music rating 180 watts
impedance 8 ohms
operating performance 1.7 watts (for 91 dB/m)
dimensions (h x d x w) 1110 x 304 x 168 mm (43.7" x 12" x 6.6")
weight 22.5 kg (50 lbs)
VC 1
Bösendorfer's smallest floor standing loudspeaker. Two-way system with one treble speaker, one bass driver /mid-range speaker and one Acoustic Sound Board.
frequency response 35 - 25,000 Hz ( ±3 dB)
crossover frequencies 130 Hz*; 2.0 kHz
power rating 60 watts
music rating 120 watts
impedance 8 ohms
operating performance 2.0 watts (for 91 dB/m)
dimensions (h x d x w) 927 x 245 x 160 mm (36.5" x 9.7" x 6.3")
weight 13 kg (29 lbs)
http://www.boesendorfer.com/
När det kommer till elektroniken kan vi erbjuda följande från McIntosh.
MCD201
SACD/CD Player
Plays CDs, CD-R, CD-RW, SACD and MP3.
Transport rotates CDs at 4 times normal read speed and SACD discs 2 times normal read speed to extract all the information from the disc.
Separate Fixed and Variable Outputs.
Balanced and Unbalanced Outputs.
MA6900
Integrated Amplifier
200 Watts/ Channel (2/4/8 ohms)
Power output meters
Output Autoformers
5 Band Equalizer
Remote control
C220
Vacuum Tube Preamplifier
7 Unbalanced High-Level Inputs
2 Balanced (XLR) Inputs & MM Phono
3 Pairs Unbalanced Outputs
2 Pair Switched + 1 Pair Fixed Outputs
1 Pair Balanced (XLR) Outputs
1/4" Front Panel Headphone Jack with Headphone Mode Mute
MC252
2-channel Power Amplifier
Stereo: 250 Watts/Channel (8/4/2 ohms)
Mono: 1 x 500 watts (16/8/4/2/1 ohms)
Power Guard and Sentry Monitor
Output Autoformers
Balanced and Unbalanced Inputs
Remote Power Control
Polished Stainless Steel Chassis
http://www.mcintoshlabs.com/
Varmt välkomna.
Kontakt information:
OJCO INTERNATIONAL AB
Kastellgatan 11B
Helsingborg
Sweden
254 66
David:0709-605777
www.ojco.se
Ojco ljud & bild
www.ojco.se
Edited by - OJCO on 2008/04/07 11:52:00
