 Pathos Digit + Classic one MKIII för demo
OJCO
Posted - 2008/03/12 :  15:02:18  Show Profile  Visit OJCO's Homepage Send OJCO a Private Message
Pathos newest CD player is dedicated to the many music lovers around the world who enjoy listening to their favorite music with a Pathos hybrid integrated amplifier.
Shaped and sized to perfectly match the Classic One, the Digit takes full advantage from the awarded reference CD player Endorphin, with which it shares most of the technology.
Pathos Digit kortfakta:
Integrerad referens CD-Spelare, Philips CD2 mekanik, uppsampling 24/192, komponentval av absolut högsta kvalitet.
Innovations about the new Classic One MKIII:
1-we use an high quality op-amp to drive the MosFet power amplifier. It is an ultra low noise, high
linearity and very low distorsion op-amp. More definition on the sound and clearer. You'll immediately
appreciate its superior sound.
2-we use a new volume control with Burr-Brown ic which is more linear and it can accept up to +/-12V audio
signal. In this way we avoid the input saturation when the cd player has high voltage output (5V). There is also
a new power supply.
3-we added a particular electronic stage to protect the power amplifiers against short-circuit on the speaker
connectors. This particular network is an high impedence stage that feels the current and save the output stage
when a short circuit happens.
4-we use a new high quality speaker connectors that are completely protected with a transparent plastic, in order
to avoid short circuit.
5-use a new stainless steel cover for the power transformer
6-new power transformer which can work up to 130Vac , so it is less sensitive to the different voltages in the US
territory.
we also supply an addictional set of spare fuses.
We use chromium plated knobs and wood of front panel is paduk (red).
Main Specifications:
Type: Integrated amplifier with remote in Class A/AB, hybrid circuit with input tube stage, bridgeable
Output Power: 2 x 70W @ 8 Ohm, 2 x 130W @ 4 Ohm, 270W in bridged mode (mono)
Inputs: 5 line, including one balanced (XLR)
Frequency response: 2Hz ÷ 100kHz
THD: <0.05%
Signal/noise ratio: 90dB
Input impedance: 100kOhm
Välkommen in för en demonstration.
Kontakt information
OJCO INTERNATIONAL AB
Kastellgatan 11B
Helsingborg
Sweden
254 66
tele 042-120230
David:0709-605777
Ove:0705-911638
www.ojco.se
Ojco ljud & bild
www.ojco.se
Edited by - OJCO on 2008/03/17 11:57:17
