 Mackie M1400 PA slutsteg*SÅLT***
räven
Posted - 2008/01/20 :  14:44:34  Show Profile  Visit räven's Homepage Send räven a Private Message
Mackie M1400, "Fast Recovery" skydd, inbyggt delningsfilter, högpass och lågpass, 1400 W mono vid 4 Ohm, 300W stereo vid 8 Ohm.
Pris 3500:-
1400 watts @ 4 ohms bridged
1000 watts @ 8 ohms bridged
700 + 700 watts @ 2 ohms stereo
500 + 500 watts @ 4 ohms stereo
300 + 300 watts @ 8 ohms stereo
Ultra-low-noise/ low-distortion design
Fast Recovery circuitry reduces distortion at the edge of clipping and beyond
Two 2nd order, 12dB/octave, Bessel low-cut filters with variable frequency from Off to 170Hz help optimize bass output of your sound system
3rd order, 18dB/octave, Bessel electronic subwoofer crossover with two selectable frequency points
Constant directivity horn EQ/Air EQ with variable frequency from 2k to 6kHz and on/off switch
Limiter with On/Off switch (decreases distortion that may become present when the M#8226;1400/1400i is driven at max levels without affecting overall sound levels)
XLR thru outputs
1/4" jacks (M#8226;1400i) or Speakon(R) connectors (M#8226;1400) and 5-way binding post outputs (both models)
Detented gain controls calibrated in dB & volts
Signal present and OL LEDs
Channel Status LEDs
Easily handles 2-ohm loads all night long
Superior T-Design cooling
ombud för Intelligent Sound
Edited by - räven on 2008/02/17 12:25:23
