 Focus Audio
Rene
Posted - 2008/01/15 :  11:22:26  Show Profile  Visit Rene's Homepage Send Rene a Private Message
Nye modeller fra FS.
The entire Classic Series is redesigned and engineered to bring both high value and affordability to the music lover.
The result exceeds our own expectations in almost every area of sonic performance.
Foot tapping musicality
See through transparency
Startling dynamics
Blinding transient speed and recovery
Exceptional tonal balance
Exacting timbral accuracy
Focused image
Three dimensional soundstage
These important sonic attributes are achieved without having to spend thousands of dollars on powerful amplification systems just to drive them. Focus Audio speakers are specifically engineered with a smooth, easy to drive impedance characteristic suitable for use with a wide variety of amplifiers.
Our designs start with a thorough understanding of the intended space in the listener's home. For smaller spaces, the Models FC6 and FC7 can thrill even the most demanding and critical of listeners with stunning transparency, neutrality, musicality and lightning speed.
In a more spacious listening environment, the Models FC8 and FC9 have the uncanny ability to recreate the life and scale of the original musical performance when so recorded. This unique level of performance and design perfection is available all throughout the new Classic Series.
For those who are looking for high definition home theater reproduction, the FCC2 center is a perfect match to the other Classic Series speaker models.
High value and affordability doesn#8217;t mean we compromise quality. Only the very best materials and components are used throughout the Focus Audio line:
Cabinets
Focus Audio cabinets are sculptured specifically to enhance imaging and are constructed with both premium grade 1#8221; MDF and on the FC7 and FC8 models up to 2#8221; thick MDF for the front baffles. The combination of varying thicknesses provides excellent acoustical properties.
Finely handcrafted cabinets are finished with premium grade real wood veneer providing the elegance of fine furniture.
Drivers
Drivers are custom made by renowned Danish driver manufacturer to Focus Audio#8217;s exacting specifications.
Innovative ring tweeters are air cooled with a non-resonant chamber-damping that provides a smooth and detailed response beyond 25 kHz, enabling low distortion even under high-powered operation.
Long throw type woofers with Nomex material driver cones are chosen for their excellent reproduction of naturally rich, dynamic and musical sounding characteristics.
Crossover
Focus Audio designed crossovers are optimized using the most advanced computer-aided programs and are then fine-tuned through painstaking auditioning. The end result is a smooth transition between drivers, wide and uniform dispersion of the sound and excellent power handling.
Each crossover is made of the highest quality components; non inductive wire wound precision resistors, ultra fast Polypropylene capacitors, high purity copper induction coils and internal wiring, hand assembled circuitry with silver solder and terminated with heavy gauge, gold plated bi-wire binding posts.
Quality control
Drivers and crossover components are computer tested and matched to ensure that they meet Focus Audio's stringent requirements.
To proudly display the Focus Audio badge, each loudspeaker must be subject to a complete quality assurance program and to perform as close to the original model as humanely possible.
For priser kik på vassagohifi.com
www.vassagohifi.dk
