 Gryphon Callisto 2100 - nu ytterligare sänkt!!!
Marc
Posted - 2007/10/23 :  23:53:13  Show Profile Send Marc a Private Message
Suverän integrerad förstärkare i absolut världsklass!
Ett elegant kraftpaket i smidigt format med Gryphons världsberömda ljudkvalitet!
-True Dual Mono configuration (äkta balanserad)
-Infrared remote control
-Flash memory upgrades via PC
-Zero negative feedback
-Microprocessor-controlled passive volume potentiometer
-Dual Mono Holmgren toroidal transformer
-Extensive mechanical decoupling
-Minimal internal wiring
-Ultra-short signal path
-Non-magnetic, non-resonant aluminum cover
-Military spec. double-sided printed circuit boards
-PCB-mounted sockets eliminate wiring and shorten signal path
-Gold-plated Swiss Neutric XLR sockets for one balanced source
-Exclusive custom Gryphon gold-plated phono sockets with Teflon insulation for 4 inputs
-Fixed-level AV throughput for uncompromising integration with surround preamplifier
-Vacuum Fluorescent Display with 2 lines and 50 characters
-Adjustable display lighting (High, Medium, Low, Off)
-Optional MM/MC phonostage module
-Non-invasive protection system
-EU CE approval
-Designed and built in Denmark
Vill du ha en high-end-anläggning i smidigt format är detta bland det bästa du kan få för pengarna!
Nypris 70 000 kr (på slutet 50 000 kr).
Nu 28 000 kr 26 000 kr 24 000 kr!!
Tranquil PC T2e -> HagUSB -> i2Digital X-60 -> Audio Aero Prima DAC 24/192 -> Acoustic Zen Absolute -> Berning ZH270 / Gryphon Callisto 2100 -> Acoustic Zen Satori -> Focal-JMlab Micro Utopia Be
Edited by - Marc on 2008/02/02 15:16:41
MaS
Posted - 2008/02/02 :  19:36:53  Show Profile Send MaS a Private Message
Var bor du?
Mvh Magnus
I ain´t no nice guy after all.
Marc
Posted - 2008/02/02 :  19:51:57  Show Profile Send Marc a Private Message
Jag bor i Stockholm.
