| Author |
Topic  |
7712 Posts |
Posted - 2007/09/12 : 15:09:02
I ett repotage i EQ Magazine påstås det att skivan skall vara varsamt mastrad och att det inte är krossad. Någon som vet om det stämmer? Kanske en bild på en mätning?
Micke |
When a man steals your wife, there is no better revenge than to let him keep her. "Se inte ner på 3 ackord låtar, tänk hur många bra vi har gjort med bara 2" Billy Gibbons ZZ Top Pälsar skall sitta på djur i skogen, inte på människor i stan. |
8784 Posts |
Posted - 2007/09/12 : 15:30:02
http://www.hydrogenaudio.org/forums/index.php?showtopic=52906
Cygnus X1 skriver:
quote: I "rushed" out to buy this new album today, and while not quite in the league of Moving Pictures or Hemispheres, S&A is definitely Rush. I'm even hearing some big riffs, keyboards, chorus pedals, and flanging on some of the songs. A nice departure from Vapor Trails!
The mastering, while a definite improvement from Vapor Trails, still isn't great, though. There's noticeable distortion on "The Main Monkey Business" and a few parts of "Spindrift,' for example, and everything is LOUD without any dynamic contrast. I suppose that's what might be expected for a 2007 rock album - I'm just not used to it since I've bought so few "new" rock albums this decade. Maybe the LP will be better - though I would hope that an album of this length would be a double LP, as the inner tracks would be squashed as hell and distorted. If they try to squeeze this on to one platter, it's going to sound atrocious.
Har du synpunkter på något? Hör gärna av dig via PM!HiFiForum.nu's Artikelregister | Regler |
7712 Posts |
Posted - 2007/09/12 : 15:50:58
Jag skall köpa tidningen men en kompis säger att de inte använt någon kompression alls under inspelningen, bara lite i mixen. Men det verkar stämma dåligt med vad du hittade ztenlund. Tack
2415 Posts |
Posted - 2007/09/13 : 15:08:46
| Kan distortionen bero på något annat än mastringen och komprimering - jag tänker på de ursprungliga ljudkällornas kvalitet, effektpedaler osv osv..? Att skivan är högt mastrad tyder ju dock på att det är komprimerat som tusan... |
Min anläggningstråd |
9125 Posts |
Posted - 2007/09/14 : 03:29:32
Skönt att fler uppmärksammat disten,trodde det berodde på min lur annläggning.
quote: and everything is LOUD without any dynamic contrast. I suppose that's what might be expected for a 2007 rock album
Hmm,tycker det är lite konstigt att ett så pass poupärt band som Rush som väl lär ha några av de bästa studio teknikerna i världen kan tillåta detta.För inte kan det väl vara så att merparten av fansen vill ha ett så pass komprimerat ljud. |
Edited by - Ryssen on 2007/09/21 00:25:01 |
7712 Posts |
Posted - 2007/09/21 : 08:58:01
Jag gav efter och köpte den men har lyssnat ganska lite för musiken var väl så där lagom kul eller behöver kanske fler lyssningar för att komma till sin rätt. Ljudet är OK modernt dvs väldigt producerat med massor av trix och fix i varje låt. Trummorna kan låta på fem olika sätt i samma låt och kanske finns det sådana som tycker det är kul men det gör inte jag. Cymbalerna är grymt hissade, typ 10-15 dB.
Skall låta den gå några varv i helgen så får vi se vad jag tycker på måndag.
Micke |
Björn-Ola
7953 Posts |
Posted - 2007/10/11 : 12:51:05
Vill tipsa lite om Trettioåriga Kriget. Utomlands anses de vara en föregångare till Rush! Kolla min tråd om Trettioåriga Kriget. |
"Innan man är riktigt säker är man ofta tvärsäker" |
Topic  |
