 Hegel H2A
Figge
Posted - 2007/03/27 :  09:46:41  Show Profile Send Figge a Private Message
Säljer mitt slutsteg från Hegel H2a:
H2A mk2 High-End Power Amplifier
Output power: More than 160W + 160W in 8 ohms, Dual mono
Inputs: RCA unbalanced and XLR balanced
Speaker outputs: Two pairs of heavy duty gold plated terminals
Frequency response: Less than +/- 0.2 dB deviation 20Hz-20kHz
Phase response: Less than 2 degrees deviation 20Hz- 20kHz
Signal to noise ratio: More than 100dB
Crosstalk: Less than -100dB
Distortion: Less than 0.006 % at 100W i 8 ohm
Intermodulation: Less than 0.01 % (19kHz + 20kHz)
Damping factor: More than 1000
Power Supply: 1000VA dual mono, 90 000uF capacitors
Output stage: 20 pcs 15A 150W high speed bipolar transistors
Power consumption: 60W in standby switched on
Size: 12cm x 43cm x 37cm (HxWxD), weight 25kg
http://www.hegel.com/system2_fidelity_no9.pdf
Nypris på Ljudmakarn 18990:- Bud över 10.000:- övervägs.
Se även test i senaste HiFi&Musik.
Edited by - Figge on 2007/05/11 16:09:31
tian
Posted - 2007/03/27 :  15:07:35  Show Profile Send tian a Private Message
Skulle sitta bra, men har ej pengar :( får nöja mig med mitt Nad C272
buris
Posted - 2007/03/28 :  12:32:06  Show Profile Send buris a Private Message
12 00 får du om jag får mitt primare sålt vad säger du om det.
buris
Posted - 2007/03/31 :  15:12:03  Show Profile Send buris a Private Message
hej har du fått nått bättre bud lr jag undrar
Figge
Posted - 2007/05/11 :  16:10:31  Show Profile Send Figge a Private Message
En som stod för sitt bud, så.
