 Project - PhonoBox Mk 2 -> SÅLD
ninja
Posted - 2007/03/24 :  19:11:58  Show Profile Send ninja a Private Message
Som ny! Finns i Göteborg....600 kr!
MM/MC Phono Pre-amplifier
Phono MM/MC selection switch located at the rear of the unit
Metal case shields the electronics from vibrational and electromagnetic interference
Small size allows installation close to record player
Special low-noise ICs used
Optimal channel separation through dual-mono circuitry
Gold plated RCA connection sockets
Outboard power supply included
Technical data
Pro-Ject Phono Box II
Input impedance, MM 47kohms/120pF
Input impedance, MC 100ohms/120pF
Gain, MM 40dB
Output voltage typically 300mV/1kHz
3mV/1kHz (MM input)
Gain, MC 60dB
0,3mV/1kHz (MC input)
Max. output 9,5V (1kHz)
Noise floor, MM 86dB (94dB - A weighted)
Noise floor, MC 68dB (75dB - A weighted)
THD, MM <0,01%
THD, MC <0,05%
RIAA-equalisation curve accuracy 20Hz - 20kHz / max. 0,5dB
Power supply type Mains-fed outboard power supply
Output voltage 16V/200mA AC
Power consumption 16V/30mA AC
Dimension W x H x D 103 x 38 x 115mm
Weight 570g without power supply
Made in SFRJ!
First they came;
HD 60 fps
Edited by - ninja on 2007/03/27 09:22:47
Comus
Posted - 2007/03/25 :  11:34:17  Show Profile  Visit Comus's Homepage Send Comus a Private Message
Hej Ninja!
Jag har sänt dig ett PM.
Mvh /
Comus
