 Extremt ljudspår av fyrverkeri.
Posted - 2007/03/23 :  07:21:08  Show Profile Send Circlomanen a Private Message
Vet inte om detta klassas som musik. (troligtvis inte) Om inte så får nån vänlig moderator flytta på tråden.
Min egna lilla Gud Tom Danley har spelat in ett ganska extremt ljudspår av fyrverkeri. MYCKET kraftig amplitud ned till 10 Hz och ca 70 dB dynamikomfång. Bränn in på CD och förstör er subb nu!http://www.danleysoundlabs.com/Finale4.ZIP
Detta är vad Tom skriver:
Well it is probably no surprise to you that I have a fondness for low frequencies and loud noises. If you have heard our speakers, I would like to think maybe its not a surprise that I am keenly interested in reproducing the "stereo image" and realism in reproduction too.
I have been developing a microphone invention for a while now and on the 4th of July, I was inspired to set it up in the back yard at my house to record the Town's fireworks which are set off about #189; mile away.
I put the last few minutes of it on a CD and have since played it (to be honest, over and over).
It was so much fun, I thought others might want to play this too.
A word of warning.
This recording has a HUGE dynamic range of about 70dB and a peak to average ratio of 40 dB. On the peaks, it is easy to clip things and the spectrum is such that the level at 10Hz is about equal with that at 50Hz (a broad mound around 25 - 30Hz).
In other words, this recording can gobble up all the headroom you have and the source is one of the most difficult things to reproduce there is from many aspects.
Preserving time and bandwidth critical so also try it on good headphones if your not impressed with it through your speakers.
Anyway, take the file and burn it on to a CD (make a couple copies one after the other) and have fun and approach maximum level carefully.
Best Regards,
Tom Danley
Edited by - Circlomanen on 2007/03/23 07:22:21
Peg
Posted - 2007/03/23 :  22:17:18  Show Profile Send Peg a Private Message
Grym inspelning !
Jag började spela, men hörde inget pga av bakgrundsljud så jag höjde och höjde och höjde tills försteget var på max vilket tyvärr inte räckte till riktigt för att det skulle kännas helt realistiskt ens på slutet. Jag ska prova igen med subben på högre nivå när min fru inte är i närheten så jag inte riskerar att bli dumförklarad igen :)
Med musik är det här normalt nivåer som mina öron inte klarar av och ändå är det här spåret för tyst trots att spåret är överstyrt på de sista smällarna !
B-200
fd. asimov66
Posted - 2007/03/23 :  22:38:25  Show Profile Send B-200 a Private Message
vad kul, detta skall testas.
Posted - 2007/03/23 :  22:48:33  Show Profile Send johan.björklund a Private Message
Ska försöka
Roq
RödaTråden Vinnare
Posted - 2007/03/23 :  23:24:57  Show Profile Send Roq a Private Message
Är det överstyrt? Jag kikade på spåret i Creative Wave Studio och vad jag kan se så styr inspelningen inte över nån gång. Ska testas på stereon
Peg
Posted - 2007/03/24 :  01:34:22  Show Profile Send Peg a Private Message
Jag tyckte tex smällen vid 3:46.22 såg klippt ut men du kanske har rätt i att den ska se sådär platt ut och att den faktiskt inte riktigt slår i taket.
Hursom helst så var mest poängen att smällarna på slutet var på max nivå.
