 Grymt bra priser på Lambda Acoustics basar!!!
Alexi
Ute och cyklar...?
Posted - 2002/11/25 :  10:24:41  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Här under följer ett mail från Nick:
Date sent: Thu, 21 Nov 2002 09:42:02 -0500
Hi Folks,
We designed a new motor assembly this summer to make a sweet lower
cost alternative to our regular drivers. Instead of the thick copper
tube we have the entire steel circuit plated with very thick copper
plating overseas. This copper plating is 1/3 as thick as the copper
tube to give an idea. (This gives alot of the performance of the high
end Lambda at a low end price) Then it is chrome plated on top of
that (you can guess where this design was intended) Well the shipment
was over 2 months late in arriving for various reasons so I have not
said much about it until now. Well some things have changed recently
and I need to move a whole bunch of these really quickly, and am
pricing them to do just that. Here is how it works;
1) You can take any of the driver specs at the website catalog except
the Dipoles and add "LE" to the beginning of the part number.
2) For modeling purposes you need to change the rated Le of the
driver from 0.2mH to 2.0mH, that is all.
3) ALL OTHER SPECS WILL STAY THE SAME GIVE OR TAKE TYPICAL
TOLERANCES
4) These use all the other same parts as our regular drivers, same
cones, voice coils, spiders, cast baskets, fancy rubber trim rings,
rubber magnet boot, gold plated binding posts, PHASE PLUGS, etc.
5) These look and weigh the same as our regular drivers, only
difference is the motor is chrome plated.
6) Even though the xmax is rated at 10mm, independent testing found
16.3 mm linear peak for you xmax nuts
7) Best of all is the PRICE! To move these out quickly;
10" = $79 each
12" = $84 each
15" = $99 each
For example you can get;
LE version of the PB12 for $84
LE version of the TD15X for $99 with PHASE PLUG
Anything in our catalog except for Dipoles can be made LE to these
prices.
Please pass this along everywhere you can, I need to move alot of
these out rather quickly, I need your help in getting the word out.
Best regards
Nick
Nicholas McKinney
Lambda Acoustics Inc.
www.lambdacoustics.com
Driver forumet faktiskt.se
Niklas Nord
Posted - 2002/11/25 :  10:51:42  Show Profile Send Niklas Nord a Private Message
då är det bara för dig att beställa..
vilka är dessa? inte de som fått bra rykte?
eller? är det PRO drivers..
lite förvirrad av hans hemsida... puhh..
Alexi
Ute och cyklar...?
Posted - 2002/11/25 :  11:05:25  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Jag har redan 4st
Men hadde jag pengar skulle jag passa på att beställa 3st till för center bakkanal den dagen jag vill ha 5.1
Alltså man kan beställa vilken som helst av deras högtalare i detta utförande!
Förutom Dipole versionen.
Niklas Nord
Posted - 2002/11/25 :  11:18:19  Show Profile Send Niklas Nord a Private Message
Och skillnanden va mindre magnet med kromad färg?
eller, hur menade han?
finns det nån 10" som har lågt FS? under 20?
jag känner inte riktigt till vad som är vad..
Alexi
Ute och cyklar...?
Posted - 2002/11/25 :  11:28:03  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Nä magneten är samma, det är innandömmet som inte är i 100% ren koppar i denna version.
Allt annat är samma.
Hm 10"... Krävs enormt tung kon för att få så låg fs på den. Lägst tror jag: http://www.lambdacoustics.com/drivers/PB10.html och
http://www.lambdacoustics.com/drivers/SB10.html har.
Niklas Nord
Posted - 2002/11/25 :  11:53:16  Show Profile Send Niklas Nord a Private Message
Är det Precission Devices som gör dessa basar kanske?
Kan man lita på data som de uppger!
Hur du uppleva dina Lambda?
Alexi
Ute och cyklar...?
Posted - 2002/11/25 :  12:03:17  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Det är Lambda själva som bygger.
Frode
Posted - 2002/11/25 :  12:29:58  Show Profile Send Frode a Private Message
Jeg hadde også bestilt hvis jeg hadde hatt penger akkurat nå. Lambda har jo et veldig rykte, jeg har faktisk aldri sett noen klage på dem. Prisen på de vanlige modellene er vel $259 uansett størrelse. Det er synd at dipolen ikke kan fåes i LE utgave.
Frode
Alexi
Ute och cyklar...?
Posted - 2002/11/26 :  20:14:28  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Jag bifogar lite intressant info från Nick:
>What will be difference for subwoofer duty between LE (SB) driver and
>regular SB driver? Crossover point will be 50 or 70 Hz. I know if
>things are too good to be true they probably are. What is the catch –
>why you don't like them (LE drivers)? Is steel degrading in you
>subjective opinion sound? My questions are only about sonic
>performance.
The steel between the LE and the regular drivers is the same.
It is the amount of copper shorting ring that is the only difference.
I prefer as much copper as I can get as I can hear the difference, but
obviously this costs money, and not everybody wants to pay me for an Apollo
design.
> You could have you own reasons don't like the drivers.
>I need subwoofer to extend low frequency for music. If you already
>build this driver could you share yours opinion on sonic differences
>for subwoofer duty? What you recommend two LE subs or one SB for
>better quality sound?
If you are happy with Vifa over Scanspeak, then you would be happy with the
LE version. That is about the best comparison I can give (Vifa and
Scanspeak are the same pretty much other than the copper ring)
>Another question is about size of drivers. Some people have opinion
>what smaller drivers better perform for music- better speed or
>transient respond??? What is you opinion? I don't need high SPL only
>quality of bass. My rooms is 9' by 11' and 12' by 25'. I've asked
>this question already but I like to get low 20th.
>What size of enclosure would you recommend to use driver in counting
>room reinforcement of sound for different driver's sizes?
I like 1~2 feet per 10" 2~4 feet per 12" and 4 feet and larger per 15"
You should fit the largest cabinet possible you can deal with for the best
sound quality.
I find that with our drivers the size didn't matter, and the 15" has the
best midrange if you can believe it. However I know it is an issue with
other driver designs because of various reasons. Most companies seemed to
not really focus on the 15" size unless they were pro sound, and as a
result the large drivers sounded like a--.
Nick
