 NHT XD #SÅLDA#
armani
Posted - 2007/02/11 :  19:42:42  Show Profile Send armani a Private Message
det är inte fel på priset och det är inte fel på konceptet, så hur kan det komma sig att dom finns kvar till salu
Nypris 89.000:- säljes för 39.000:- med andra ord 50.000:- billigare jag tar inbyten
finns alla kartonger samt dokumentation i absolut nyskick
Probably the best-sounding and best-looking
small speaker system.
The NHT Xd speaker system reaches for greatness, and achieves it in some specific ways. Its big, bold, large-as-life sound comes from a gorgeous compact speaker system. In fact, it#8217;s probably the best-sounding and best-looking small speaker system that I#8217;ve had in my listening room. But the audible hiss through the XdSes, the mechanical whine from the XdA, and the auto-sensing glitch of the XdW mean that, despite greatness in some areas, there are bugs in the electronics that preclude it from being the breakthrough product that it purports to be -- and potentially will be if these bugs are fixed in the future. Please address these issues, NHT!
Doug Schneider, July, 2006 SoundStage
#8220;The Xd powered speaker system isn't just about using new technologies and designs#8212;it's about using new technologies and designs to truly make speakers sound better. Take one listen, and you'll agree that NHT has entirely succeeded at this. The system sounds great, it looks great, and it couldn't be much easier to use.#8221;
Chris Lewis, November, 2005 Home Theater
Summing Up: Art Dudley recently wrote that the true test of a component, under review, is how you feel when it comes the time to returning it to the manufacturer. In the case of NHT's Xd, I felt bad about having to send it back. It did almost all of what I want an amp and speakers to do, with very little downside. However, I have five pairs of speakers on deck for review and I have to move on.
In the meantime, the revised crossover software, in conjunction with stereo subwoofers, has taken a relatively affordable, excellent-sounding loudspeaker system and made it almost beyond criticism. It's true that the NHT Xd system still lacks ultimate dynamic range, but there's only so much you can ask in terms of ultimate loudness from a pair of drive-units with a radiating diameter of just 3". Highly recommended.
John Atkinson, Stereophile
Stereophile:
http://www.stereophile.com/standloudspeakers/1105nht/
http://www.stereophile.com/standloudspeakers/1105nht/index5.html
HomeTheater:
http://www.hometheatermag.com/subsatloudspeakers/1105nht/
SoundStage:
http://www.soundstage.com/revequip/nht_xd.htm
Länk till DEQX som står för programvaran:
http://www.deqx.com/index.html
Power Physics som står för de digitala slutstegen:
http://www.powerphysics.com/
NHT:
http://nhthifi.com/2006/s-s-ultimate.html
XD Filters:
http://nhthifi.com/2006/service-xd-xdsxdw.html
The Xd is the new gold standard for music reproduction. It is #8220;objectively#8221; the finest transducer currently on the market and it is being continually being refined. The digital technology is the most advanced ever to grace a speaker and the acoustic design is absolutely state of the art. It outperforms $10,000/pr, $20,000/pr speakers, even $50,000/pr speakers andn includes the power amplification, stands, subwoofer, cables and DSP processing, for a mere $6000/pr. For more information
* Time/phase corrected
* 4096 bands of digital frequency response correction
* Ultra Steep 110dB/octave and 48dB/octave phase correct crossovers
* 24/96 Analog to Digital Converters
* Dual 32-bit Analog Devices SHARC Processors with upgradeable card
* USB input for software upgrades
* Actively tri-amplified with built in Power Physics digital amplifiers
* 150W for each tweeter/midrange
* 500W in each subwoofer
* Advanced Room Correction option
* Future parametric EQ/high output options available
* Future wireless subwoofer option
* Dual stereo subwoofer option
* Top of the line SEAS aluminum tweeter
* Top of the line SEAS Excel magnesium midrange
* Ultra dense poured composite cabinet design
* Low diffraction front baffles for wide dispersion
* Sub/Sat design for vibration isolation, small form factor and ideal placement
* Force cancellation bi-pole subwoofer for low vibration and excellent isolation
* Balanced subwoofer connections with 20' cables for placement flexibility
* 12V Trigger input or music sensing for automatic on/off
* Included, matched speaker stands connect to the speakers for child resistancy!
* 4-conductor speaker wire included
* Incredibly easy to setup and enjoy!
Strengths:
o Time/phase correction yields near perfect coherence and integration
o Acoustic Suspension design offers superior transient response and bass precision
o Frequency response correction provides near perfect accuracy
o Compact cabinetry for precise, focused imaging
o Steep crossovers and low diffraction baffle creates massive soundstage
o Incredibly light, rigid metal drivers for superior resolution
o Steep Crossovers yield substantially lower distortion and higher output
o Low diffraction baffle and steep crossovers proved huge sweet-spot and soundstage
o High output subwoofers provide real, unexaggerated 26Hz
o Dual sub/deep bass option for real 20Hz response
o Room Correction yields near perfect room/speaker interface and freedom from boominess
o No passive crossover parts and tri-amplification transmits maximum clarity and low-level resolution
o Huge soundstage and sweet-spot for idealized high performance home theater
Telefon: 070-726 93 06
Finns i Sthlm/Älvsjö
Edited by - armani on 2007/04/05 13:45:06
