 Intergrerad förstärkare Perreaux 200IP *SÅLD*
Rasmus
Posted - 2007/01/11 :  19:05:39  Show Profile Send Rasmus a Private Message
En Perreaux 200IP till salu.
Snabbfakta:
2 * 200w /8ohm
2 * 300w /4ohm
Separerade för och slutsteg
Försteg jobbar helt i klass A
Slutsteget jobbar i klass A upptill 10w som sedan går över i klass A/B
En test:
http://www.soundstage.com/revequip/perreaux_200ip.htm
Bilder:
http://www.minhembio.com/Dr.Watson/83678/
Hårda fakta:
Preamplifier Section
Rated Output: 1.5Vrms
Maximum Output: 3.0Vrms
Input Overload: 4.0Vrms
Tape Output Level: 200mV
Input Impedance:
Unbalanced 10kohm
Balanced 30kohm
Input Sensitivity:
Unbalanced 205mV
Balanced 430mV
Total Harmonic Distortion (THD+N):
Rated Output <0.006%, 20Hz to 20kHz
Frequency Response: 20Hz to 20kHz, ±0.15dB
Signal to Noise Ratio: 95dB
Phase Accuracy: ±1.0º, 20Hz to 20kHz
Dynamic Range: 110dB
Power Amplifier Section
Continuous Power Output (per channel): 200Wrms into 8ohm
300Wrms into 4ohm
Typically 0.004% @ 1kHz into 8ohm
20Hz to 20kHz <0.020% into 8ohm
Frequency Response: 20Hz to 20kHz, ±0.25dB
Hum & Noise (unweighted): -95dB, referenced to rated output
Dynamic Headroom (rated with music): >1.9dB
Maximum Current Output: 24A per channel
Damping Factor: >500 @ 1kHz into 8ohm
Input Impedance: 22kohm
Input Sensitivity: 1.5Vrms
Driver Stage: Class A
Output Stage: Class A/AB
In/Out
5 pairs Unbalanced Inputs (RCA)
1 pair Unbalanced Direct Inputs (RCA)
1 pair Balanced Inputs (XLR)
1 pair Unbalanced Power Amplifier Inputs (RCA)
1 pair Unbalanced Preamplifier Outputs (RCA)
2 pairs Unbalanced Line Outputs (RCA)
General
Dimensions:
Width 430mm
Height 106mm
Depth 460mm
Weight: 18.0kg
Nypris låg på ~29000:-
Pris idé 8000:-
Finns i Sthlm.
/Rasmus
0709-428272
Edited by - Rasmus on 2007/01/14 15:43:10
Linus78
Posted - 2007/01/11 :  21:38:11  Show Profile Send Linus78 a Private Message
Hur trivs den med ett par Martin Logan?
Rasmus
Posted - 2007/01/12 :  12:37:53  Show Profile Send Rasmus a Private Message
Linus: Jag kan inte svara iom att jag aldrig provat...Men jag gissar att den trivs jätte bra =)
Linus78
Posted - 2007/01/12 :  15:19:55  Show Profile Send Linus78 a Private Message
Ok, hittade lite reviews på den och de verkar komma bra överens. Jag slår dig en signal när jag mätt upp spänningen.
Rasmus
Posted - 2007/01/14 :  15:45:15  Show Profile Send Rasmus a Private Message
Lycka till Linus! Tack för en smidig affär! =)
Edited by - Rasmus on 2007/01/14 15:45:51
Denna sida genererades på 0.4 sekunder. Snitz Forums 2000
