 Transparent PI 8 recenserad
Hi Fi Consult
Posted - 2006/11/27 :  20:19:05  Show Profile  Visit Hi Fi Consult's Homepage Send Hi Fi Consult a Private Message
Vi saxar ur Bryan Southard:s recension på Audio Video Revelution:
"With its simple cosmetics and superb build quality and performance, the PowerIsolator 8 is my choice to compliment my reference system. As you can tell by the components that I possess, I demand the very best money can buy and the PI8 is exactly that.
If you are looking to improve the performance of your AV gear and want a product without compromise, give the Transparent PowerIsolator 8 a listen in your home. And when you do, go ahead and clear a spot in your rack for the audition, because the PI8 is not likely to leave."
Läs hela texten här
http://www.avrev.com/equip/transparentisolator/index.html
High Fidelity testade PI 8
http://www.hificonsult.se/uploads/Transppowerisolatora%231C4662.jpg
www.hificonsult.se
