 Förstärkare, Jungson JA-88D - *SÅLD!*
l99_man
Posted - 2006/09/25 :  11:21:39  Show Profile Send l99_man a Private Message
¤ JungSon's unique Class A full-balanced and non-negative feedback circuit
¤ 80 W Class A output per channel
¤ Balanced (XLR) and non-balanced (RCA) inputs
¤ JungSon's unique heat sink - a 1.8 m² copper radiator
¤ Nature hard wood remote control with digital stepping volume adjustment
¤ Fully sheathed and anti-shock aluminum alloy case
¤ Ocean blue LED power meters
Technical Data
Output Power:________80 W per channel, Class A, RMS, 8 ohm
THD+N):_____________0.05%
Frequency Response:__20 Hz-20 kHz ± 0,5dB
S/N:________________100 dB
Inputs:______________balanced and unbalanced available
Input impedance:_____100 kohm
Output Impedance:___ 4 ohm - 16 ohm
Power Voltage:_______AC 220 V±10%, 50-60 Hz
Dimensions:__________430x500x210 mm (WxHxD)
Net Weight:__________30,5Kg
Remote Control:______IR, wooden enclosure
http://www.mfl-importexport.com.au/content/reviews/jungson.pdf
Pris: 8900kr 7900kr
Skicka gärna ett mail om du är intresserad till: martin01@kth.se
eller ring 0708-101013.
/Martin
Edited by - l99_man on 2006/10/24 15:42:39
