 *såld* Sony DVP-NS930V DVD/SACD *såld*
Kaleid
fd. "Halbermensch"
Posted - 2006/05/14 :  00:17:48  Show Profile Send Kaleid a Private Message
Regionsfri spelare i toppskick.
Frakt kan ordnas med bussgods (111kr) alt. posten.
SACD/DVD/VCD/SVCD/CD/MP3 Player
DVD+RW/DVD-R/RW (video Mode)/DVD-RW (VR)/CD-R/RW playback
Super Audio CD 2-channel/ Multi-Channel playback
Precision Drive 2 with Dynamic Tilt Mechanism
Precision Cinema Progressive (NTSC)
Precision Cinema Progressive (PAL)
Block Noise reduction and Digital Video Enhancer
12 bit/108MHz Video D/A Converter
Dolby Digital & DTS Decoder
192kHz/24bit Audio D/A converter for Super Audio CD
96kHz/24bit Digital Output
192kHz/24 bit Audio D/A Converter
Multi-Disc Resume (40 discs)
Playback Memory (40disc)
Front Aluminum panel
Multi-Brand TV & Receiver Control Video
Precision Cinema Progressive (NTSC/PAL)
(V Edge Compensation)
(Pixel-by-Pixel I/P conversion)
12bit/108MHz Video DAC
Block Noise Reduction
Video Equalizer
Info:
http://www.sony-mea.com/product_details.asp?InpProdId=5187
Recensioner:
http://search.ecoustics.com/a.php?search=Sony+DVP-NS930V+
Edited by - Kaleid on 2006/05/21 22:30:32
MullBenkt
Posted - 2006/05/20 :  04:39:36  Show Profile Send MullBenkt a Private Message
Var finns den?
Kaleid
fd. "Halbermensch"
Posted - 2006/05/20 :  05:00:05  Show Profile Send Kaleid a Private Message
Skövde
Mc Square
Posted - 2006/05/20 :  05:37:18  Show Profile  Visit Mc Square's Homepage Send Mc Square a Private Message
Du kan inte öppna locket,så man kan se lite av insidan...?
Behöver en ny dvd jag med!
-->Mitt system
EoJeud - A better snack!
Mc Square
Posted - 2006/05/20 :  05:41:55  Show Profile  Visit Mc Square's Homepage Send Mc Square a Private Message
Eller det behöver du inte göra förresten...
Om vi delar på frakten så tar jag gärna den.
Matte
Edit:Vad väger den?
-->Mitt system
Edited by - Mc Square on 2006/05/20 05:44:27
Kaleid
fd. "Halbermensch"
Posted - 2006/05/20 :  05:52:55  Show Profile Send Kaleid a Private Message
På lådan så står det 5kg, men spelarens vikt är enligt minhembio sida på 2.8kg
Kommer det inget högre bud under helgen så är spelaren din Mc Square
