 Ang meridian 861 på engelska ,tyvärr
Carlos
Posted - 2006/04/09 :  20:34:58  Show Profile Send Carlos a Private Message
But the quality of the prossesor regarding dd and dts istn changeged thru the 1 2 3 4 ?
Its a verry important question for me since i am not going to use the 800 and be able to take advatage of dvd audio.
And another question, ive seen pages http://www.meridian-audio.com/p_861.htm in the meridian homepage that talks abot a 2,5 , what that all about ?
tommypeters
Posted - 2006/04/09 :  20:57:30  Show Profile Send tommypeters a Private Message
(Take this with a small grain of salt)
Meridian does the processing in software, so in theory the quality should be the same. However, since they have changed processor boards they may not still update FW for all four major versions (major is first number, 1/2/3/4). So an older version may be stuck with an older version of the algorithms, as the new sazzy configuration program only works on version 4.2 and up. The second number is a minor version, usually no big hardware changes. So the 861 can be version 2.5, 4.2...
They are pretty bad at updating their web site, so version 2.5 was probably the current version when they designed that web page. Then they added "In the latest Version 3 we have also added high resolution multichannel digital and analogue input options." with a link to version 3: http://www.meridian-audio.com/p_800_861V3.htm - a page for version 4 may come any year.
BC Acoustique ACT A3
NuForce Ref8.200W
Velodyne DD-15 & DD-12
