 Peerless HDS 134
Niklas Nord
Posted - 2002/11/06 :  18:35:01  Show Profile Send Niklas Nord a Private Message
Ser ut att kunna funka bra till linjekälla, de kan monteras
tätt ihop, det är bra.
kurvan ser äckligt bra ut. och de är säker billiga, kanske
under 500:-
HDS 134
134 WR 26 90 SD AL 8 ohm - Order ID: 850488
A High End mid-woofer with rigid aerodynamic cast aluminium basket profile and ventilated spider. The basket provides the necessary sturdy base for the magnet structure and suspension and allows for long excursion of the cone. The spider is ventilated to achieve the lowest possible compression and to allow air to flow freely to create a cooling effect for the voice coil. The design of the basket front allows for very slim box designs and the edges are chamfered to re-duce the necessary amount of counter sinking.The three or five layer sandwich cone improves accuracy and consistency of sound reproduction over the entire frequency range, creating a more "musical" driver. Due to the soft suspension, an excellent dynamic small signal reproduction is obtained. Other features are high sensitivity, gold plated terminals and very low harmonic and difference tone distortion. This woofer is applicable on a wide range of applications, and is especially ideal for small 2-way bookshelf boxes as well as multiple alignment for floorstand boxes.
HDS 134
Thiele Small parameters: Free air Common Baffled
Nominal impedance Zn (ohm) 8
Minimum impedance/at freq. Zmin (ohm/Hz) 6.4/376
Maximum impedance Zo (ohm) 34.6
DC resistance Re (ohm) 5.7
Voice coil inductance Le (mH) 1.0
Capacitor in series with 8 ohm
(for impedance compensation) Cc (µF) 7
Resonance Frequency fs (Hz) 61.1 59.9
Mechanical Q factor Qms 2.07 2.11
Electrical Q factor Qes 0.41 0.42
Total Q factor Qts 0.34 0.35
F (Ratio fs/Qts) F (Hz) 172
Mechanical resistance Rms (Kg/s) 1.89
Moving mass Mms (g) 10.2 10.6
Suspension compliance Cms (mm/N) 0.67
Effective cone diameter D (cm) 10.8
Effective piston area Sd (cm²) 91
Equivalent volume VAS (ltrs) 7.6
Force factor Bl (N/A) 7.4
Reference voltage sensitivity
Re 2.83V 1m at 376 Hz (Measured) (dB) 89.2
Magnet and voice coil parameters:
Voice coil diameter d (mm) 26
Voice coil length h (mm) 14
Voice coil layers n 2
Flux density in gap B (T) 1.24
Total useful flux (mWb) 0.83
Height of the gap hg (mm) 6
Diameter of magnet dm (mm) 90
Height of magnet hm (mm) 15
Weight of magnet (kg) 0.4
Niklas Nord
Posted - 2002/11/06 :  18:36:41  Show Profile Send Niklas Nord a Private Message
de lär inte ge djupbas, men de lär kunna prestera i alla fall
ned till 60 - 70hz hoppas jag.
och jag kan dela vid 1000 - 12000 hertz
JAG tycker kurvan ser äckelpäckelbraig ut.
nån annan som håller med?
FAST NÅGRA MÅTT PÅ DEN HAR JAG INTE HITTAT!!!
Nagref
Posted - 2002/11/06 :  18:59:14  Show Profile Send Nagref a Private Message
Det är Peerless urkassa på! Skärpning!
VD för Acoustic Landscape
jan
Hög Fidelitet
Posted - 2002/11/06 :  21:27:13  Show Profile  Visit jan's Homepage Send jan a Private Message
Hvad betyder "äckelpäckelbraig"? Nogen som kan oversætte? Er det negativt, så forstår jeg det inte, for kurven er da jättefin.
Ja, Peerless mangler at angi målene (mått) på sine enheder. Jeg skrev en e-mail til dem for et år sedan och dom lovade at få det ordnat. Intet er sket!
Nu det handler om HDS serien, så er 8" jättebra och den går langt ned! En rigtig bas, som ochså kan anvendes i linjekilder op til omkring 2.000 Hz.
Jan Nielsen
http://www.pladespilleren.dk
kung
Posted - 2002/11/06 :  21:34:35  Show Profile Send kung a Private Message
det betyder jävligt bra .)
Niklas Nord
Posted - 2002/11/06 :  21:44:01  Show Profile Send Niklas Nord a Private Message
"äckelpäckelbraig" = superdiscustinglySuperSuperbSravoExellent
a damn good driver that is!
JAN
just 134:an har inga peaks som jag kan se, men det har de
andra, så där får man im,plementera notch -filter, och det
känns lite sådära onödigt om jag ändå inte behöver bas under 65hz
i linjekällan, och mindre element works fine!!
vh
n/a
deleted
Posted - 2002/11/06 :  21:49:28  Show Profile Send n/a a Private Message
Hej NN!
Måtten på
-är 134 resp 152mm, djup är 64mm( el för den som inte kan/orkar med, A*udiomanska:
Mvh A*.
Edited by - n/a on 2002/11/06 21:51:55
n/a
deleted
Posted - 2002/11/06 :  21:59:30  Show Profile Send n/a a Private Message
Har själv använt 6,5:an som låter mkt bra, kan tänka mig att den mindre låter än bättre.
Kvaliet/pris, helt suverän.
Kör på den du!
Niklas Nord
Posted - 2002/11/06 :  22:06:41  Show Profile Send Niklas Nord a Private Message
TACK A*
de är lika intressanta i pris/förhållande,
som seas excell verkar asgrymma
badoooong
n/a
deleted
Posted - 2002/11/07 :  10:42:39  Show Profile Send n/a a Private Message
Hej NN!
Kom på 1st ytterligare eventuell LS-kandidat!!
Fostex FE103-Sigma, som är en 4" som går extreeemt djupt( för att vara 4", ed ;) o mkt högt.
A har endast provat sina lätt sporadiskt i liten BR-Låda, fullrange o det lät okej men fick redan då idéen om att
använda dem som midar, så vem vet??( inte A, ed ;)
Om man köper +10 så går de nog att få för under 500 SEK/st.
För vidare info se: http://www.diyparadiso.com/datasheets/speaker/fostex/fe103.pdf
Mvh A*.
Edited by - n/a on 2002/11/07 10:49:25
n/a
deleted
Posted - 2002/11/07 :  11:27:43  Show Profile Send n/a a Private Message
Originally posted by Audiomaniker
Hej NN!
Mvh A*.
Har också använt FE103Z som fullrange, mkt fint mellanregister!
Det kan vara bättre att köra med den vanliga FE103,
(pdf filen som A länkar till ovan) då FE103Z har en kraftig resonans i mellanregistret.
Kraniet
Posted - 2002/11/07 :  12:53:20  Show Profile Send Kraniet a Private Message
Enda grejjen som jag funderat på är det faktum att modellen med fasplugg har kopparklätt polstycke vilken den utan fasplugg inte har.. Men faspluggen verkar dock ha enormt värdelösa effekter på frekvensgången..
Så vad tar man? Eventuellt lite mer distrsion fast bra frekvensgång.
Eller
Lite mindre distorsion fast en värdelös frekvensgång.
Jag väljer nog det förstnämnda..
Carlssoninspirerade självbyggen
NAD 2200
Källa? Dator..
"Tur man inte vet alla problem innan man börjar, då skulle det nog aldrig bli något diy..
n/a
deleted
Posted - 2002/11/07 :  12:54:34  Show Profile Send n/a a Private Message
Hej c!
Okej så det finns olika FE103:or iaf( 2st: Sigma samt "icke-Sigma", ed ;). Glömde nämna det men A´s
FE103-sigmor hade även de ngn form av peak i höga-mellan/låga-diskanten men om de vanliga
FE103:orna saknar denna( peak ) kan nog de vara att föredraga.
Vad är egentligen skillnaden mellan FE103-sigma/FE103??
Mvh A*.
svensson
många inlägg är det....
Posted - 2002/11/07 :  12:59:14  Show Profile Send svensson a Private Message
Tack A*, nu förstår jag vad du skriver.... ;=)
Det börja tidigt, så tidigt jag minns....
n/a
deleted
Posted - 2002/11/07 :  13:06:29  Show Profile Send n/a a Private Message
Hej c!
Mvh A*.
Den skillnaden jag vet om är att Sigma versionen har en större magnet, lägre Fs och kan jobba lite högre upp i frekvens(22Khz tror jag), plus en peak i mellanregistret/diskant...
