Author |
Topic |
Niklas Nord
6152 Posts |
Posted - 2002/06/10 : 10:05:35
Kolla in denna som jag fick av en entuiast från fjärran land..
Använder SCSI fläta, sådan i datorer, och det verkar som om Nordost blitt skeptiska till hans beställning av denna fläta...
"Hello,
I tested a lot of cables among the most renowned among which Nordost SPM. Today, I use the cable ribbon SCSI (ref: F3001S-68-025-85) from Tempflex and I am very satisfied. It is less expensive and much better. Probably because the conductors are thiner. (30AW, solid silver plated copper). The insulation is Teflon FEP. When I make it test to friends, they adopt it at once. The difficulty consists in stripping the threads AWG30.
Attention, if you want it, try to buy it at wholesalers as Granite Gigital for example rather than directly at Tempflex. It seems that they have a contract of exclusivity with Nordost. When the boss of Nordost, Joe Reynolds, learnt that I hadordered 2,000 ft, he made blocked my order believing that I was a retailer. Finally, I succeeded in getting myself it in France but 3 times as expensively. For info, I use it on a system 7 ways high efficiency with horns. I tested a lot of cables among the most renowned among which Nordost SPM. Today, I use the cable ribbon SCSI (ref: F3001S-68-025-85) from Tempflex and I am very satisfied. It is less expensive and much better. Probably because the conductors are thiner. (30AW, solid silver plated copper). The insulation is Teflon FEP. When I make it test to friends, they adopt it at once. The difficulty consists in stripping the threads AWG30.
best regards, jean-yves kerbrat"
n/a
deleted
1623 Posts |
Posted - 2002/06/10 : 18:25:17
Hej påre Niklas N!
Bra tips, ska sätta A på det. Ditt inlägg gjorde att A fick någon slags Deja vû då det blev som om att Hej påre Niklas N! Bra tips, ska sätta A på det. Ditt inlägg gjorde att A fick någon slags Deja vû då det blev som om att Hej påre N......
Mvh A |
Niklas Nord
6152 Posts |
Posted - 2002/06/10 : 19:55:55
Såja A.
Jag ska faktiskt testa detta, har en del SCSI hemma, men det måste typ vara LVD, kostar MASSOR, tusentals kronor för 4meter..
tror jag iaf, av det jag sett!
hum... testa ska jag nu göra!
hejdå A
n/a
deleted
1623 Posts |
Posted - 2002/06/10 : 20:47:07
Hej Niklas N!
Är det flat eller rund SCSI-kabel som menas?? Sen, "Jag ska faktiskt testa detta," -Varför skulle du inte göra det??, verkar ju vara kanonbra.
Det A menade med "deja vû" var att i texten så börjar det om här: "efficiency with horns. I tested a" , -precis efter punkten .
Mvh A |
Niklas Nord
6152 Posts |
Posted - 2002/06/10 : 21:00:35
flat..
finns olika sorter, skall höra mig för, men jag tror det är LVD kabel, som klarar flest mb dvs!
försilvrad koppar
Michaels
74 Posts |
Posted - 2002/06/11 : 19:55:03
har tittat lite på Flatkablar, dom kan ju vara riktigt snygga också.. Om man inte skulle vara nöjd med ljudet menar jag...
//Michae |
Topic |
