 Quad L-series subwoofer säljes
bruce
Posted - 2006/02/19 :  12:59:49  Show Profile Send bruce a Private Message
Quad L series 300watt Subwoofer säljes
Vill du köper den så kostar den 50% av original priset alltså 4450:- + eventuellt frakt
Subwoofern är köpt före året på AudioConcept och kostade 8900:- ny.
Färg Rosewood
Subwoofern är grym musikalisk (en riktigt hifi sub) med en snabb och torr bas, samtidigt utmärkt med film. Passar utmärkt med tex Quads elektrostater eller L serien så klart!
Mer info finns på Quads hemsida.
Kan skickas.
Om det önskas kan jag maila Quad L series subs Manual till dig.
Bilder kan skickas via email.
Another first is the Quad L-Sub active subwoofer system.
An exceptionally refined unit, the L-sub can be used to great effect within both stereo and multi-channel systems.
If your penchant is for standmount speakers but you find the bass response too limited, the addition of the L-sub will provide the necessary sub-sonics to enhance your enjoyment.
Although a sub-woofer can be placed anywhere in a room as bass
frequencies are essentially non-directional in nature, you may choose
to leave the L-sub a little more exposed.
The same high-gloss piano finish is applied to the subs making them as attractive as they are sonically adept.
Features of the L-sub include an extremely high power 300WRMS
amplifier module, a choice of six discrete filter paths, from 35Hz to
85Hz in 10 Hz steps, a full feature remote control, microprocessor
controlled volume and four memory settings which can be set and
recalled from the remote.
L-Subwoofer - active
Specifications
Drivers
Bass 12" 300mm Tri-laminate carbon/glass fibre sandwich cone
Mid n/a
Tweeter n/a
Amplifier Power Output 300W (rms)
Input Impedance 10k Ohm
Frequency Response (-6dB) 25Hz - 90Hz
Low Pass filter range 35Hz-85Hz (plus by pass) in 10 Hz steps
Maximum Power Output 113dB @ 1m
Facilities Phase select, high/low inputs, remote control, 4 programmable memory settings
Gross / Net weight 31.6kg, 29kg
Height 525mm
Width 340mm
Depth 465mm
brorie@gmail.com
Edited by - bruce on 2006/03/01 09:35:22
Gaffa
fd. Mabuse
Posted - 2006/03/02 :  01:20:12  Show Profile  Visit Gaffa's Homepage Send Gaffa a Private Message
Är det någon som har en aning om hur subben går till HFLS-1?
Skeptic Friends Network
Manga X
Donator: Bildserver
Posted - 2006/03/02 :  09:52:54  Show Profile Send Manga X a Private Message
Jag tror att denna sub integrerar bra med allt!
Den har ställbara delningsfilter (via fjärr) och är helt makalöst bra i mitt tycke!
Vore den i en annan färg var den redan såld.
Mvh Magnus Eriksson
bruce
Posted - 2006/03/02 :  21:43:20  Show Profile Send bruce a Private Message
Sorry gubbar, men subban är ej till salu längre. Efter en hel del funderingar idag och lyssnande, är det bara inte i mitt bästa intresse att sälja den. Har inte haft några seriösa köpare heller. Tar gärna bort denna tråden.
Edited by - bruce on 2006/03/02 21:43:46
Gaffa
fd. Mabuse
Posted - 2006/03/03 :  01:10:28  Show Profile  Visit Gaffa's Homepage Send Gaffa a Private Message
Trist... Jag var genuint intresserad.
