 Hegel H2A
Figge
Posted - 2006/02/05 :  10:25:57  Show Profile Send Figge a Private Message
Ej till salu längre
Hegel H2A
Endast 8 månader gammalt.
Pga av övergång till integrerad förstärkare.
Balanserat slutsteg
Hegel H2A
Från tillverkarens hemsida.
H2A High-End Power Amplifier, 2x160W 8 ohms, 2x400W 2ohms.
The H2A power amplifier is the smaller brother of the H4A Reference Amplifier. Based on the same technology as the bigger sibling, the H2A offers identical features and 2x160 watt / 130A. Unmistakably HEGEL, with the characteristic curved front panel, and uniquely user friendly with its single power button. A discrete blue control light indicates that the amplifier is on.
Behind it's confident panel, the H2A has extreme power reserves and is capable of powering all available speakers. H2A can deliver a consistent signal of more than 130 A. It is not only designed to drive large and complex speakers,- it is also detailed and delicately precise to be used with small and medium speakers.
A dual-mono construction, the H2A is using two exclusive new Patented SoundEngine circuits in the amplification stages. The H2A can be connected to both balanced and unbalanced input sources. The speaker outputs has got two sets of heavy duty high quality gold plated terminals for both channels.
What is new?
Voltage gain stages. Each channel is now divided into completely
separate voltage - and current gain stages.
For the listener this will give a higher dynamic range, better improved position of instruments and smoother high frequencies.
Tester:http://www.hegel.no/h2a_rev.htm
Nypris:18990 kr
Nu:11500:-
Erbjudande med Rogue Metis rörförstag, se föregående annons.
Mobil: 0705-130 670
Edited by - Figge on 2006/04/08 11:06:31
