 En blindtest av kablar
Posted - 2006/02/03 :  12:19:41  Show Profile Send Micke Y a Private Message
Det här är UHF magazine's senaste (?) publicerade blindtest av kablar. de har gjort sådana förut men den här finns tillgänglig i elektroniskt format
Läst med rätt glasögon är den ganska intressant.
http://www.uhfmag.com/Issue74/UHF74.pdf
silvervarg
Posted - 2006/02/03 :  15:14:18  Show Profile Send silvervarg a Private Message
Intressant läsning, speciellt delen med eko-signaler i digitalkablar så att en längre kabel kan vara bättre än en likadan kortare.
Dessa stycken ur testet med högtalarkablar är intressnat:
Note that we had not touched the
volume after we had listened with our
reference cables. But Albert thought the
piece now sounded as though we had
backed up a few rows in the concert hall,
and wondered whether it might sound
fuller with perhaps 3 dB more juice.
Actually we all did.
And it was much better with the extra
volume. The depth — which this SACD
has in wholesale quantity — was much
more apparent, and the male singers had
found the vigor they had seemed to lack.
The bottom end seemed bulked up as
well
We should add that this phenomenon
is something we’ve run across before: we
make a change in a cable, and we have the
impression that the volume knob needs
a twist. That effect does not correspond
to a drop in level that a meter could
measure. Whatever its cause, we much
prefer it to the opposite effect, in which
we have the impression that the music is
now way too loud.
Vänta nu...de väljer här att lyssna utan att det är nivå-matchat. Är inte det att missa grundkurs 1A?
Edited by - silvervarg on 2006/02/03 15:15:31
Baltazar
Posted - 2006/02/03 :  15:35:09  Show Profile Send Baltazar a Private Message
Jo, det var ju ett seriöst blindtest Man lyssnar blint och sen fipplar man med apparaterna tills det låter bra
Edited by - Baltazar on 2006/02/03 15:39:19
Posted - 2006/02/03 :  15:38:18  Show Profile Send Micke Y a Private Message
measure.
Det finns ett antal saker som står här i att ifrågasätta men trots det finns det intressanta delar.
tommypeters
Posted - 2006/02/03 :  22:22:03  Show Profile Send tommypeters a Private Message
Att upplevd volymändring inte stämmer med mätt är väl inte så konstigt, men då behöver man göra en mätning över hela frekvensområdet för att se vilka frekvenser som påverkats och samtidigt kontrollera ev. ändrade tidsfördröjningar. Örat är ju olika känsligt för olika frekvenser, våra huvuden likaså - men ljudtrycksmätare funkar ju inte "psykoakustiskt". Så möjligen har frekvensinnehåll ändrats, något fasförskjutits, eller något annat hänt som får dem att uppleva ljudet som lägre.
BC Acoustique ACT A3
NuForce Ref8.200W
Velodyne DD-15 & DD-12
