 Dynamic Precision A2
cybwiz
800.000-klubben
Posted - 2006/01/30 :  19:39:13  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message
Dynamic Precision har lansert A2; et stort beist av en effektforsterker.
Prisen blir 190 000,- NOK, senere kommer A5 som blir toppmodellen.
OUTPUT POWER, RMS, 20Hz-20kHz,
@ 1% THD (clipping level) :
8 Ù load, 400W per channel
4 Ù load, 800W per channel
2 Ù load, 1500W per channel
8 Ù load, 1500W bridged mono
Maximum output current: More than 100A per channel (200A peak)
DISTORTION, THD @ 400W 20Hz-20kHz in 4 Ù load:
Less than 0.0005%
DISTORTION, THD @ 35V RMS, 1 kHz: Less than 0.0001%
IM DISTORTION, CCIR 13 kHz and 14 kHz, 8 Ù load: Less than 0.0002%
FREQUENCY RESPONSE(filter bypassed): DC - 500kHz -3dB
SLEW RATE(filter bypassed): Greater than 250V/us
DAMPING FACTOR: 1000 @ DC - 20kHz/8Ù
SIGNAL/NOISE RATIO, Ref. 400W/8Ù load:
10Hz-80 kHz 107dB
22Hz-22kHz 114dB
10Hz-CCIR-QPK 103dB
IEC-A weighted 116dB
INPUT IMPEDANCE: 200 kÙ
GAIN Pos 1: 26dB (20x)
GAIN Pos 2: (standard setting)30dB (31,6x)
GAIN Pos 3: 33dB (44,7x)
SENSITIVITY Pos 2: 1,42 V RMS for 250W/8Ù
CHANNEL SEPARATION: More than 120dB@ DC -100kHz
COMMON MODE REJECTION RATIO: Better than 100dB@ DC -100kHz
DIMENSION (W x H x D in mm)445 x 364 x 380
WEIGHT (kg)65
http://www.dynamicprecision.no/
http://cybwiz.blogspot.com/
Edited by - cybwiz on 2006/02/01 00:40:05
Posted - 2006/01/30 :  19:46:39  Show Profile Send johan.björklund a Private Message
Lagom Best
Creative Audio
Posted - 2006/01/30 :  19:55:42  Show Profile  Visit Creative Audio's Homepage Send Creative Audio a Private Message
Tänk om han äntligen kom med försteget oxå !!!
http://www.creative-audio.se
Posted - 2006/01/30 :  20:59:21  Show Profile Send Circlomanen a Private Message
Verkligen fina steg! Vill ha!!!
Jag gillar hans kretslösningar med flytande nätdelar mm..
snare2
Posted - 2006/01/31 :  20:09:40  Show Profile Send snare2 a Private Message
Jag var på besök hos Leif i somras & fick möjlighet att lyssna till hans försteg & bla till div kommande nyheter.
De finn i allafall att köpa i Norge.
Ni kan läsa på föjande bildtråd....Håll till godo
http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=41306&SearchTerms=resa,till,dynamic,land
Snare2
Fideljr
Posted - 2006/01/31 :  23:23:46  Show Profile  Visit Fideljr's Homepage Send Fideljr a Private Message
Vad då komma med försteg ????
jag ett försteg från DP som är ifrån 2000 så jag förstår inte vad du menar eller har du inte koll på DP
When you listen to the music, don't listen to the sound!
cybwiz
800.000-klubben
Posted - 2006/02/01 :  00:35:42  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message
"Tänk om han äntligen kom med försteget oxå !!!"
Hvilken pre er det du tenker på? En kommende C2?
DP lager 3 forskjellige C1 pre. iflg deres site.
C1b til 25000,- NOK
C1 - ?
C1s - 45000,- NOK
Hva er forskjellen på C1 og C1s? - de har like specs.
1b
1s
For en komplett DP oversikt over alle deres produkter, sjekk ut http://home.monet.no/~kaiped/
Edited by - cybwiz on 2006/02/01 00:44:45
Denna sida genererades på 0.21 sekunder. Snitz Forums 2000
