 Audiofilkabel till HD600/650 ** 1500:- ** Såld **
Ampalang
fd. drbob
Posted - 2006/01/23 :  21:08:37  Show Profile Send Ampalang a Private Message
Stefan Audioart Audiofilkabel till Sennheiser HD 600/650
Högre öpplösning och mer dynamik, tystare bakgrund och ett myller av detaljer.
Nypris 320$
Pris 1500:-
Skicka PM eller maila på oralinkontinens@hotmail.com
Edited by - Ampalang on 2006/02/08 19:58:43
Ampalang
fd. drbob
Posted - 2006/01/24 :  21:02:42  Show Profile Send Ampalang a Private Message
Equinox HD650/600/580
Audiophile Headphone Cable
the Equinox cable is a handcrafted audiophile headphone cable specifically
designed for the Sennheiser HD650, HD600 and HD580 headphones.
Sonic Description: a rich, natural, involving presentation, with excellent soundstage
width and depth. Full low frequency extension with natural, detailed high frequencies
and ultra smooth midrange. Increased definition and presents allowing the user close association with the impact of the music.
Construction: 4-conductor quad-braid field geometry cable consisting of ultra high
purity copper with individual strain isolation enclosed with a Teflon/Oxygen dielectric finished in black Techflex with white cabling . The cable incorporates gold plated
Sennheiser spade connections and is terminated with a professional 3.5-mm heavy-duty black handle connector with gold contacts or professional 1/4" termination with silver contacts. The connectors are applied to the cable with Stefan AudioArt's exclusive
Ultra-Solder Process (Patent rights issued and/or pending).
The Equinox cable is constructed using an ergonomic assembly process and is light
and extremely flexible due to variable-lay geometric construction and compressed Techflex covering. Incorporating the original locking Sennheiser spade connectors into the Equinox cable design, insures the best possible interface (both mechanical and electrical) with your Sennheiser headphones. The refined Sennheiser spades lock into the headphones molded port for trouble free operation and provide optimal contact with the headphone counterpart. Furthermore, no unexpected modification to your Sennheiser headphones is required as might be the case with other after market headphone cables.
Specifications:
Compatibility: Sennheiser HD650, HD600 and HD580
9-ft Cable weight without 3.5-mm/1/4" termination: 90 grams / 2.9 ounces.
Cable geometry: oval variable-lay construction 8-cm x 6-cm.
The combination of the highest quality proprietary materials along with precision hand-craftsmanship, enables the Equinox cable to be the ultimate sonic improvement with unsurpassed flexibility for the Sennheiser HD600/580 headphones. Follow this link to read what users have to say about the Equinox cable
ulfsan
Posted - 2006/01/25 :  10:02:33  Show Profile Send ulfsan a Private Message
Hur lång?
Zombie
Posted - 2006/01/25 :  10:21:55  Show Profile Send Zombie a Private Message
jämfört med Cardas dito?
Ampalang
fd. drbob
Posted - 2006/01/25 :  11:07:37  Show Profile Send Ampalang a Private Message
Måste sovit när jag skrev annonsen
Kabeln är 15ft lång (4.57 m)
Har inte jämfört med Cardas men lite tester och så finns här
http://stefanaudioart.com/CableReviews.html
